2000 civic boosted b16 problems
Old Feb 10, 2013 | 11:31 PM
G_thirty_5's Avatar
Icon3 2000 civic boosted b16 problems
I made a post before about it dying out on me when i drive or when its
Started. I thought i fixed it but i guess i didn't please help guys..
Its not the ignition switch or the main relay or the fuel pump.
Any ideas??? The car runs a lil rough aswell. Btw i need some advice as
How much boost should i be running if I'm driving it daily? Its a b16 with gsr pistons and after market valves. Right now I'm boosting 15 Psi. I know that's way too much.
Old Feb 11, 2013 | 12:53 AM
jbpnoman's Avatar
Default Re: 2000 civic boosted b16 problems
PSI means absolutely nothing. 15 PSI through a T2 is perfectly safe. 15 PSI through a T60 would grenade the motor and probably leave it unrecognizable.
Check your mechanical and ignition timing. Check for CEL codes.
Old Feb 11, 2013 | 02:12 AM
grumblemarc's Avatar
The Grumpiest
I knew it wasn't the "ignition coil fuse". What EMS are you running? Is this even tuned? Fuel system upgraded? What are your AFRs like? Datalogging? Running a wideband?
I already know the answer to all of those questions is no. You probably have a shitty basemap. Take it to a tuner.
Old Feb 11, 2013 | 10:09 AM
Psychoteen101's Avatar
I was thinking the same thing...
Until you post usable specs about your COMPLETE setup in detail, you might as well be throwing darts and buying whatever part it lands on.
all_motorsi
Engine Management and Tuning
Jul 7, 2008 04:08 AM
Maxime
Sep 7, 2004 11:55 AM
B18C1_CRX
Feb 28, 2004 06:19 PM
7rrivera7
Jan 16, 2003 01:51 PM
saso
Apr 30, 2002 01:50 PM
