Forgot to install thrust washers?
Old Jan 20, 2013 | 01:05 PM
ceearexx's Avatar
Default Forgot to install thrust washers?
So my friend bought a motor off one of his friends friend. It is a sleeved 84mm gsr block. I don't know who it was assembled by but i am guessing they didn't not install the thrust washers? The motor ran it made it to the dyno and still made 700+ hp. It had a lot of blow by and sounded kind of weird right after the dyno he decided to check it out. He got to open it up and found no thrust washers! There was a lot of metal shaving from the crank and block being chewed up by the crank wobbling side to side (you can see in the pic where the thrust washers are suppose to sit it wore it down i dont think i can even use the block because the next washers wont sit right?). The sides of the pistons had scrapes on them and the bottom of the pistons were smacking the oil squirters braking 2 of them right off and damaging the pistons. misspelled
This is the only pic i have right now but, i will post more pics up later today or tomorrow morning.
Let me know what you think went wrong?
Old Jan 20, 2013 | 01:19 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Forgot to install thrust washers?
block is fucked, crank is fucked
cannot be fixed or used again
also check the head, with that many shavings it probably clogged the pickup causing oil starvation which in turn scored the cam journals
and what went wrong? you said it yourself NO ******* THRUST WASHERS
they take up lateral play in the crank so the crank doesnt move horizontally in the motor, without them the crank will slide back and forth beating against the block and caps.
i'm also willing to bet your cutch and flywheel is damaged as well as potentially the transmission, since the flywheel would be smacking into the input shaft... the oil pump is probably fucked too due to the crank slamming around the pump gears
Old Jan 20, 2013 | 01:24 PM
ekcoupeh22's Avatar
Throw everything in the garbage or use it for a mock up motor crank walked=motor fucked
Old Jan 20, 2013 | 01:30 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
This one actually got me laughing. I can only imagine things like throwing belts every time the clutch was pushed in. Haha... that one would go on "The Wall" for sure if I had it.
Old Jan 20, 2013 | 01:32 PM
wantboost's Avatar
Who is Mr Robot?
i don't even see how you'd forget to put them in.... maybe the crank moving back and forth while checking end play (like you're SUPPOSED to) would be a dead giveaway? or maybe those extra bearings left over?
Old Jan 20, 2013 | 04:04 PM
SovXietday's Avatar
I'll take that motor off your hands, I have been looking for a mockup motor. One with a funny *** story behind it is even better.
Old Jan 20, 2013 | 05:01 PM
DDTECH's Avatar
Where's the share button for facebooking lmao..
Old Jan 20, 2013 | 05:03 PM
wantboost's Avatar
Who is Mr Robot?
ive got plenty lol
Old Jan 20, 2013 | 05:06 PM
grumblemarc's Avatar
The Grumpiest
You can "Like" it. Bottom left.
Old Jan 20, 2013 | 05:08 PM
Spawne32's Avatar
I cant even laugh at this, i almost forgot my thrust washers the other day reinstalling my crank. I was sitting it on the mains and i felt this feeling like i was missing something. lol
Old Jan 20, 2013 | 05:16 PM
wantboost's Avatar
Who is Mr Robot?
liked lololol
Old Jan 20, 2013 | 11:17 PM
ceearexx's Avatar
Alright then i guess the block is garbage ill let him know. lol I knew what happened i just wanted to see what you guys thought about what happened.
He also told me to ask if there is anyway to remove the dry sleeves it has right now and put them in a new motor? of course done by a machine shop! Just a simple NO will do lol
Old Jan 21, 2013 | 12:21 AM
wantboost's Avatar
Who is Mr Robot?
not the block, everything.. clutch, flywheel, and probably the transmission... i bet the input shaft is beat to **** and wiggles.
you need to check the cam journals for scoring
and unless you cut the block away from the sleeves, they aren't coming out
Old Jan 21, 2013 | 07:34 AM
hjdanzi's Avatar
How can someone build a 1000hp motor and forget to install those?
Old Jan 21, 2013 | 07:42 AM
DO IT ON ALL FOURS
Drugs/Alcohol.
Old Jan 21, 2013 | 09:35 AM
ceearexx's Avatar
thats what i was thinking lol cutting the oem sleeves completely off and getting them out.
Old Jan 21, 2013 | 09:44 AM
hjdanzi's Avatar
Originally Posted by N3va3vaSatisfi3d
Drugs/Alcohol.
lol, yeah probably, or even a wife... I can imagine her at the phone, dont forget to pick up the kids, and dont forget that the fridge is broken, and call susan is her ******* bday...
The guy totally forgot about the thrust washers lol
b18bc3po
17
Oct 8, 2009 07:28 AM
Swipe'd
Mar 3, 2007 06:17 AM
HmgLauj69
33
Mar 2, 2004 07:27 PM
