Where to install EGT sensor probe in header?
Old Jan 18, 2013 | 10:29 PM
Corksil's Avatar
Default Where to install EGT sensor probe in header?
Hey I am installing an EGT gauge in my car. I have a few questions.
Exhaust runner #3 is the hottest in a Honda b-series engine, we can all agree on that.
My probe will be installed in the third runner (unless I hear otherwise.}
The probe has a threaded bung which must be welded to the outside of the manifold and drilled for proper fitment.
I plan to have a local shop weld the bung so the probe sit in the third runner, pointed close to the head - the probe is roughly 2.5 inches long (I will measure it this weekend}.
Here is my planned fitment...
Due to the length of the probe I want to install it right where the header pipe starts to turn, so it will sit ~1/2" from the head and read the hottest temp.
Okay so now for my questions...
- Is this the optimal location for the probe?
- Can I have this bung welded with the header ON the car? Not a welding expert and don't want the welder to damage any sensors or overheat anything by welding with the header ON the car - but I'd rather not remove the header if I don't have to.
Thanks I'll have more questions as this thread develops.
Old Jan 19, 2013 | 04:32 AM
Steeve_Civic's Avatar
Default Re: Where to install EGT sensor probe in header?
If not a Turbo engine it is not necessary, just your AFR into the downpipe
Old Jan 19, 2013 | 06:04 AM
grumblemarc's Avatar
The Grumpiest
No FI?
Old Jan 19, 2013 | 06:38 AM
SiRCiviC94's Avatar
ive been debating on getting one. is it best to have the wideband closer to the turbo outlet or the dp collector is ok? i have another bung closer to the turbo that might be more accurate?
Old Jan 19, 2013 | 07:19 AM
92cxyd's Avatar
You are drilling in the wrong location.
#3 is the third runner from the timing cover, you have #2 marked.
Old Jan 19, 2013 | 07:47 AM
TheShodan's Avatar
Moderator
*EDIT* The firing order is from right to left, but Helms illustrations have it the other way around fpr some reason. According to the Helms and Honda service manuals, this person is drilling in the right spot. From actually looking at it, its the wrong spot
From AUTOZONE
92cxyd is referencing THIS
I thought I was one of the few left that ran an EGT.. All the young people run... well, only God knows what anymore.
Old Jan 19, 2013 | 08:12 AM
wantboost's Avatar
Who is Mr Robot?
^see that's how I've always done it... #3 from distributor, not timing cover
I wonder what the FSM says, as I have NGK plugs that are labeled 1 as the shortest and 4 as the longest wire
And since it appears your are NA, there's no real reason for am egt gauge, you'll never generate temperatures anywhere near monitoring
Old Jan 19, 2013 | 08:15 AM
rich7777's Avatar
Supercharged maybe ????
Old Jan 19, 2013 | 08:19 AM
TheShodan's Avatar
Moderator
Very true... I made a terrible assumption.
Old Jan 19, 2013 | 08:29 AM
wantboost's Avatar
Who is Mr Robot?
Still, a jrsc won't produce that kind of exhaust gas heat, at least not enough to worry about monitoring.
You need to worry more about intake temps...
And technically, unless you can monitor all four cylinders simultaneously then it really serves no point as you don't know what the other cylinders are at
Old Jan 19, 2013 | 08:43 AM
TheShodan's Avatar
Moderator
Right, and that's where the confusion lies when this is asked a lot. I'll go back to my car and check, I believe I'm at the correct "#3".
From HELMS
Looks correct. And the person wanting to tap is the wrong order
Old Jan 19, 2013 | 08:52 AM
wantboost's Avatar
Who is Mr Robot?
Which also means I was right and muckman had his done wrong and too (#2 from dizzy)
Old Jan 19, 2013 | 08:59 AM
abs0Lut's Avatar
always start from front(timing chain/belt) and work your way back(flywheel/tranny) when counting cylinder numbers.
Old Jan 19, 2013 | 09:01 AM
The Grumpiest
Not.
Old Jan 19, 2013 | 10:07 AM
turbohatch96y7's Avatar
Icon5 Re: Where to install EGT sensor probe in header?
From AUTOZONE
In both of these pics the number 3 runner is in the same place. 3rd from the timing belt. In the black and white pic notice where the distributor mounting bolt is. Its in the top left. Number 3 cylinder is still in the same place as the other pic.
Old Jan 19, 2013 | 10:41 AM
Corksil's Avatar
JRSC
Originally Posted by grumblemarc
No FI?
JRSC
JRSC
JRSC
JRSC
Not.
JRSC
Old Jan 19, 2013 | 10:52 AM
Corksil's Avatar
GTFO my thread and make your own question with your own cool pictures like I did. Your acronyms are confusing, plz go get DP'd by goats in the bung.
Yes it appears you are correct.
From AUTOZONE
Yeah thanks for clarifying. So it sounds like I AM drilling in the right spot. Regardless of the numbering, is the cylinder marked in the OP still the hottest?
I am running a JRSC if you recall from your 10+ posts in my thread about the optimal pulley configuration to attain 9.8psi of boost.
Whether I need the gauge or not isn't really the point of this thread but thanks for the info. I am running the gauge for a number of reasons which are also irrelevant but I could explain if you really want to know.
I agree about the IAT. It's the intake temps that are dangerous. That's why I'm running methanol/water injection.
Also I agree that ideally one EGT probe on each cylinder would be ideal, but I can't afford that nor do I have the space in my car for four EGT gauges. This is the best compromise - have you heard that the 3rd runner is the hottest? It's the piston that always melts down first (speaking from personal experience and research I've done.)
So my OP is incorrect and I should be going for the other middle-runner?
Thanks for the clarification
Cool
Good to know.
Old Jan 19, 2013 | 10:58 AM
Corksil's Avatar
Thanks to everyone who posted and I appreciate the feedback.
I'll weld the bung to the OTHER middle runner... #3 in this picture
Can anyone comment on whether I must remove the header from the engine before doing the welding? I don't want to mess up any sensors on the head/block with the welding process, but removing the header is a pita if not required.
I could easily drive the car into the welding shop, let him pull up a bucket to sit on, let him weld the bung and drill, then thread a little bolt in to plug the hole and the whole project would take less than 30 minutes. Removing the header would be more difficult.
Old Jan 19, 2013 | 11:00 AM
Corksil's Avatar
Not.
You again. Plz go. You have it out for me on a personal level as you have 'explained' to me via PM. You have no place posting in my threads. Please add me to your ignore list. If you have a problem with this message, PM me - Do not continue to muddle my threads with your particular brand of negativity.
Thanks!
Old Jan 19, 2013 | 11:35 AM
T ake off the header. You dont want all the metal shavings in your exhaust unless your running an open header.
If you have a muffler, I would take the header off or at least disconnect the 2 bolt flange and blow the shavings out before you start the car.
Old Jan 19, 2013 | 11:36 AM
TheShodan's Avatar
Moderator
That's up to you and your welding shop. it is best to remove the header and put it in the #3 runner (from the actual illustration I posted) on the underside of the header about 3-4 inches from the head flange. It will be the leanest cylinder.
Old Jan 19, 2013 | 11:43 AM
SiRCiviC94's Avatar
calm down there corkslow you dont even know your own engines firing order take your car to a mechanic.... monitoring 1 runner is a waste of time for such a slow car anyway.
Old Jan 19, 2013 | 11:46 AM
Corksil's Avatar
Thanks everyone.
I will remove the header from the car before I have it drilled/welded. I had considered the metal shavings but I have no turbo downstream so I figured they wouldn't damage anything in the freeflowing exhaust system. I forgot about the O2 sensor. It will also be easier for the welder to get the bung on right if the header is off the car.
Bump for optimal location confirmation..
Old Jan 19, 2013 | 11:48 AM
Corksil's Avatar
Heh heh heh. Get on my level kid.
Old Jan 19, 2013 | 12:18 PM
wantboost's Avatar
Who is Mr Robot?
It really is pointless on a jrsc car... you aren't at any power levels high enough to worth about high egts
And just because #3 tends to run hottest doesn't mean you can't have an issue on another cylinder
