sc34 shaft bearing?
Old 02-04-2013, 02:55 PM
carlos8's Avatar
Default sc34 shaft bearing?
hi, i'm tryng to find the shaft bearing for my precision sc34 but all i can find is for garrett and they use the standard 2 bearing system and my turbo use a single long bearing. Any point of oder repair kit i can use? I found the
bearing alone but not for my turbo just for garrett gt15,gt17 etc.
thanks in advance
Old 02-04-2013, 03:00 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: sc34 shaft bearing?
No journal bearing turbo uses one continuous bearing unless you're talking about the outer cage of a ball bearing unit
And when the sc34 was being built, precision was still using Garrett parts
Old 02-04-2013, 03:11 PM
carlos8's Avatar
well i need to talk with the shop, cause they tell me the garrett kit with the 2
bearings was incorrect for my turbo. tomorrow i try to post a picture of wath
they call the single shaft bearing.
Old 02-04-2013, 03:54 PM
Moderator
TheShodan's Avatar
Please pick the proper number and part
Old 02-04-2013, 04:35 PM
Who is Mr Robot?
wantboost's Avatar
I've never seen a unit with a single journal bearing.
Old 02-04-2013, 04:41 PM
carlos8's Avatar
it's like the part# 732252-0001 journal bearing for garrett.
from. greensource rebuild parts
they say the part number 13 in your list isn't used in my turbo.
Old 02-04-2013, 04:46 PM
Moderator
TheShodan's Avatar
That part number represents a full bearing service kit for the GT-R series from GT15-GT22. Those would never fit a SC34 or journal bearing cartridge. Your turbine shaft is too large.
You need a JOURNAL BEARING Kit system for the Garrett T3/T04 series
Old 02-04-2013, 04:48 PM
Who is Mr Robot?
wantboost's Avatar
That's only for small shaft turbos... have you ever seen a gt15? Its the size of a coke can...
There's no way your unit uses a single bearing, shaft is too big and given its length wouldn't adequately control axial and radial loads.
Post a picture of what you physically have.
Old 02-04-2013, 04:51 PM
Who is Mr Robot?
wantboost's Avatar
So unless you have a ball bearing sc34 (which has one big outer cage, could be confused for a journal bearing by the unfamiliar) but I've never seen any precision unit with a single bearing
And this discrepancy from unit to unit within each model range is absurd and goes to show you how precision can't keep a supplier.. and is a main reason I'll never use their products.
Old 02-04-2013, 05:24 PM
carlos8's Avatar
i'm going to pick up the turbo and the kit tomorrow and find another place.
Isn't easy here localy to find quality turbo shops, most of them ask you to
broght the repair kit.
Old 02-04-2013, 05:35 PM
Moderator
TheShodan's Avatar
That just sucks. you might as well send it out to get repaired or get another unit. When one of the guys out there tried to "Freshen up" LocoJoe's Reaper (There was nothing wrong with it), they wound up replacing it with the wrong parts entirely. They actually made it WORSE, then if it was just left alone.
Time to ship it back to the U.S. and get it done properly.
Old 02-04-2013, 05:46 PM
Who is Mr Robot?
wantboost's Avatar
There is a really big turbo shop down there, I'll have to remember the name, I see them on eBay all the time and they have a really good reputation.
Old 02-04-2013, 06:36 PM
LocoJoe's Avatar
Carlos where in PR are you?
Old 02-04-2013, 06:46 PM
carlos8's Avatar
i'm in Bayamon.
Old 02-04-2013, 06:50 PM
LocoJoe's Avatar
Call Speed & Turbo Center in Rio Piedras 787-754-8484
OR
Turbo Center in Caparra 787-783-8547
Old 02-04-2013, 07:09 PM
carlos8's Avatar
thanks, for speed & Turbo center number.
I'm going tomorrow to Turbo Center.
Gracias
carlos
Old 02-04-2013, 07:11 PM
LocoJoe's Avatar
A la orden
crzyfool24
08-21-2004 03:09 AM
ridnmyhonda
03-08-2004 10:29 PM
Kack
01-27-2004 02:35 PM
Charlie Moua
03-20-2003 12:17 PM
Quick Reply: sc34 shaft bearing?
