my turbo build problem
Old Feb 2, 2013 | 02:23 PM
67mmlsv's Avatar
Default my turbo build problem
hey guys i just finished building my lsv build
parts consist of
BLOCK
CP 9:1 PISTONS 81.5MM
EAGLE RODS
ACL BEARINGS
STOCK LS CRANK, MICRO POLISHED
FRESH BORE AND HONE
HEAD
SUPERTECH VALVES,RETAINERS
GSR CAMS
SUPERTECH VALVE GUIDES
TURBO
BORG WARNER S300
TIAL 44MM WASTEGATE
BLUERIDGE MOTORSPORTS TOP MOUNT
FULL RACE INTERCOOLER
MY QUESTION IS THAT AFTER THE MOTOR WAS ALL ASSEMBLED WE TRIED TURNING THE CRANK OVER AND IT WAS REALLY TIGHT BUT THEN IT WOULD LET LOOSE AND TURN OVER A LITTLE TIGHTER THEN NORMAL. EVERYTHING WAS TORQUED TO SPEC AND PLATIGUAGE. WE EVEN TURNED IT WITH THE HEAD OFF AND SAME THING. SO WE WENT AHEAD AND INSTALLED IT IN THE CAR AND WHEN WE TRIED TURNING THE CAR ON WITH THE STARTER, THE STARTER COULDNT SPIN THE FLYWHEEL CAUSE IT WAS TIGHT.SO IS THIS NORMAL ON A MOTOR THAT HAS A FRESHH BORE AND HONE ,AND CRANKS BEEN MICRO POLISHED AND EVERYTHING IN SPEC
Old Feb 2, 2013 | 02:46 PM
turbohatch96y7's Avatar
Default Re: my turbo build problem
nope not normal. my crank turned over by hand when i rebuilt my motor. some thing is tourqued to tight. pull the pan and main caps
Old Feb 2, 2013 | 03:05 PM
Turbo-LS's Avatar
The crankshaft should turn over easily by hand during assembly. What was the specs when you did the plastigauge ? Did you use assembly lube on all the mains and rods and cams etc.. ?
Either way that motor needs to come out and be torn down to find the problem. If you didnt lube then order bearings and pray you didnt damage crankshaft. there are a lot of variables here but it all boils down to that crank should turn over by hand.
Old Feb 2, 2013 | 03:15 PM
67mmlsv's Avatar
i used royal purple assembly lube , yea the cranks turned by hand ,im saying when the entire block was assembled ,thats when it was hard.......we lubricated everything very well , cylinder walls ,bearings, piston rings, everything
Old Feb 2, 2013 | 04:09 PM
phaphon's Avatar
your rods big ends are probably out of round ? did you buy them new or used?
Old Feb 2, 2013 | 04:22 PM
wantboost's Avatar
Who is Mr Robot?
It shouldn't turn over that easy with the head on and torqued. Even the you're fighting compression at certain points.
But during assembly before the head goes on, it should spin like butter
But before you go blaming the bottom end, is your electrical system healthy? (Battery, alternator, solid electrical connections) and have tried a different starter? Maybe yours is on the way out
Old Feb 2, 2013 | 04:31 PM
67mmlsv's Avatar
everything in the motor is brand new,all my electrical is good , battery is new and so is starter. i blame the bottom end because it was doing the same thing with the head off the block. im thinking its the main or rod caps being to tight , im gunna check em tommorow but im positive i torqued it to 56ft lbs
Old Feb 2, 2013 | 08:00 PM
phaphon's Avatar
i had this happen a couple times on me . my mistake was not making sure the rods wernt out of round .
Old Feb 7, 2013 | 09:40 AM
nu2teg's Avatar
Double check that the rods and pistons were installed correctly.
https://honda-tech.com/forums/forced-induction-16/eagle-rod-pistons-instal-3059788/
This might be where your bind is coming From.
Old Feb 7, 2013 | 12:49 PM
DirtyDA9's Avatar
Its probably from the compression, once the valves open it becomes easy to turn, then harder again.
Old Feb 8, 2013 | 07:17 AM
Hondatuner911rs's Avatar
what turbo is that, very nice!!!
Old Feb 8, 2013 | 07:32 AM
jubbeng's Avatar
its ur main, either caps are out of round or crank journal, im guessing u went with .0015 clearance.
Old Feb 9, 2013 | 03:06 PM
CRAWFORDBUILT's Avatar
Sounds like either the crank has warped, the block needs to be line bored/honed, or the big end fillet needs to be checked.
Old Feb 9, 2013 | 03:08 PM
Clean engine bay though!
tdrewd
Sep 28, 2012 10:17 AM
EFPhilly
43
Jan 12, 2010 08:52 AM
jmac
Mar 26, 2008 11:04 AM
99problemssss
Jan 13, 2006 09:17 AM
Importordomestic
Oct 21, 2005 06:45 AM
