Gm 3 bar map sensor plz help quick!!
Old Jan 6, 2013 | 02:29 PM
CoLoRnK's Avatar
Default Gm 3 bar map sensor plz help quick!!
Hello
I'm switching my map sensor from a no name to gm 3bar. The tube on bottom on the sensor does not go in the throttle body opening for it. Tried to search up if anyone else had similar issue but no luck. Could this be manufacturer defect?
Old Jan 6, 2013 | 02:38 PM
dpetro1's Avatar
Default Re: Gm 3 bar map sensor plz help quick!!
can you be more specific? i am not following. can you take a pic of what you are talking about.
most 3 bar sensors so not bolt onto the TB. you run a separate vac line to it.
Old Jan 6, 2013 | 02:46 PM
TheShodan's Avatar
Moderator
You have to get the accompanying "pigtail" to wire it in. You must block the original location of the stock map sensor so no air gets to it. swap the three wires into the oem Map sensor wires on the wiring harness. It won't do any good until you have the management ready to go and calibrated, so don't swap until completely ready.
Contact Xenocron, I believe he has the instructions available for you..
http://www.xenocron.com/3-bar-map-se...35b55e6a3df6c9
Old Jan 6, 2013 | 02:52 PM
CoLoRnK's Avatar
Sounds like you guys are not visualizing same thing I am lol, let me uploa a pic next commercial break go skins!!!!
Old Jan 6, 2013 | 03:05 PM
CoLoRnK's Avatar
Dan I'm trying to figure out how to post pic from my gallery
Old Jan 6, 2013 | 03:11 PM
CoLoRnK's Avatar
U guys may be right I think I need to run aseperate vac for this
Old Jan 6, 2013 | 03:17 PM
CoLoRnK's Avatar
Can anyone post a pic of the gm sensor mountede I'm having no luck on google
Old Jan 6, 2013 | 03:25 PM
dpetro1's Avatar
second result on google images
Old Jan 6, 2013 | 03:56 PM
wantboost's Avatar
Who is Mr Robot?
The gm 3bar will not bolt to a stock throttle body.... it didn't bolt to anything on gm cars either so its not a defect, you need to block the stock map off, or bolt the stock map in and don't plug it up..
You need to run a vacuum line to the sensor off the intake manifold and you'll need the gm pigtail to splice into the OEM harness since the stock map plug won't work
Old Jan 7, 2013 | 04:49 AM
CoLoRnK's Avatar
Thanks guys, sorry about the trouble was on here using my iphone.
Old Jan 7, 2013 | 07:38 AM
blackeg's Avatar
I also have mine bolted to the firewall. That nipple just used a vacuum line to a source from the manifold or where ever
spoolinq
Sep 22, 2010 10:34 AM
ForceFed Motorsports
Mar 7, 2008 03:57 PM
turbolshatch
Feb 2, 2006 06:06 AM
redlseg
Jul 29, 2005 10:07 AM
nick-vti
Aug 10, 2004 09:27 PM
