Intake/Compressor boost sources. Which to W/G, which to BOV
Hey guys, just curious ihow I should be routing my lines. I have 2 available boost sources for my external wastegae and my bov. One source is a large vacuum nipple off the intake manifold, and the other is the nipple on the compressor housing.
Which of those sources should I use for the bov and which for the wastegate/manual boost controller lines
Thanks alot
Thanks alot
Re: Intake/Compressor boost sources. Which to W/G, which to BOV
I would use manifold vacuum for the bov.
Edit: you may find this thread handy: https://honda-tech.com/forums/forced-induction-16/wastegate-blow-off-valve-hookup-howto-3005324/
Alright, Ill have to get some sort of adapter as the intake manifold barb is 3/8" while the bov is quite a bit smaller
bov requires vacuum, I opt for the largest nipple/source.
i like to run the nipple off the turbo for the wastegate, usually cleans up a line running across the engine bay.
Who is Mr Robot?
You have to run a source after the throttle body for the blow off valve... or it won't work
Compressor housing will work for the wastegate but if you're running off the spring you'll see lower pressure at the intake manifold due to pressure drop
