Darton Sleeved Engine Question
Old Jan 10, 2013 | 09:08 AM
turboHondaWesJ's Avatar
Default Darton Sleeved Engine Question
Greetings HT. I found a used longblock (h22a1; closed deck) that ostensibly has Darton sleeves; however, the balance shafts are still in place (seems like an unusual move to reinstall them after sleeving?). Anyone ever heard of such a practice? TIA
UPDATE:
Okay guys. I decided to take a chance on the sleeved block. Can anyone positively identify them? TIA
Old Jan 10, 2013 | 09:13 AM
ninesecrx's Avatar
Default Re: Darton Sleeved Engine Question
Just because the engine is sleeved does not mean you cant use the balance shafts. That being said you would be correct, most people who build perf. engines plug the oil feed holes and get rid of them. It is not too late, you can still do so.
Old Jan 10, 2013 | 09:48 AM
I appreciate the response; apologies if my original post seemed ambiguous. I wouldn't keep the balance shafts. I'm more concerned with whether or not the block actually has Darton sleeves (as opposed to just FRM pistons in a stock block). My offer to him will be significantly lower if the latter is true. Any other H/F builders out there who kept/reinstalled their balance shafts after sleeving?
Old Jan 10, 2013 | 11:38 AM
wantboost's Avatar
Who is Mr Robot?
We need pictures to tell you if it's sleeved.... if the top of the liner is two different colors then its probably stock
Again, just because it has balance shafts doesn't mean it isn't sleeved, some builders think its better to leave them i I.e personal preference.
Old Jan 10, 2013 | 11:47 AM
TheShodan's Avatar
Moderator
I typically remove balance shafts on these engines like the DSM 4G63.
Old Jan 10, 2013 | 12:05 PM
I appreciate the help. Not sure I'd be able to produce such a picture unless I buy the engine (it's currently an assembled longblock).
That's the plan
Old Jan 10, 2013 | 12:06 PM
wantboost's Avatar
Who is Mr Robot?
Well take it on faith
Or remove the front coolant fitting on the block, you should be able to tell machine work has been done
Old Jan 10, 2013 | 12:23 PM
What should I look for specifically? I will ask the seller to remove the fitting and snap a pic. Thanks for the ideas!
Old Jan 10, 2013 | 12:54 PM
MalcolmV8's Avatar
What exactly are balance shafts?
Old Jan 10, 2013 | 12:56 PM
MalcolmV8's Avatar
Must be a B series thing
http://en.wikipedia.org/wiki/Balance_shaft
Old Jan 10, 2013 | 01:00 PM
90blackcrx's Avatar
You can still remove the balance shafts, I recommend to remove them and pick up a KStuned balance shaft eliminator kit.
Old Jan 10, 2013 | 01:26 PM
Originally Posted by MalcolmV8
H/F engines have them. B/D don't
Old Jan 10, 2013 | 01:36 PM
That's the plan. Thanks Bob
Old Jan 10, 2013 | 02:00 PM
MalcolmV8's Avatar
Thanks. Figured that out eventually after reading that wiki page.
Old Jan 10, 2013 | 04:09 PM
The following are a few pics that the seller sent (side note: for my own edification I asked the seller what size allen is needed to remove the coolant plugs; he relayed that a 14mm is needed). Verdict? Darton or stock?
Old Jan 11, 2013 | 03:35 AM
Thoughts?
Old Jan 11, 2013 | 04:08 AM
wantboost's Avatar
Who is Mr Robot?
i need a pic in the hole, not of the hole. and whats the crap on the sleeve?
I've never seen sleeves that color or with material on them, looks like frm to me
Old Jan 11, 2013 | 04:09 AM
wantboost's Avatar
Who is Mr Robot?
ductile iron sleeves are machined, they would be smooth, not have that cast like surface
Old Jan 11, 2013 | 05:14 AM
I'm not sure what that is.
I emailed Darton; they responded saying that they can't tell from the aforementioned pics. The Darton rep said that I would need to have the seller pull the head in order for them to give a definitive answer.
Old Jan 11, 2013 | 06:16 AM
wantboost's Avatar
Who is Mr Robot?
no aftermarket ductile sleeve has a a surface like that
thats definitely a cast liner
Old Jan 11, 2013 | 06:21 AM
rich7777's Avatar
Stick a magnet pen through the hole and see if it sticks to it.
Old Jan 11, 2013 | 06:22 AM
So that is definitely the outside of the sleeve (and not part of the block)? Excuse my ignorance. I appreciate the help.
Old Jan 11, 2013 | 06:24 AM
Ha! That's clever! The cast/stock sleeves don't contain iron?
Old Jan 11, 2013 | 06:34 AM
wantboost's Avatar
Who is Mr Robot?
The block is cast with an aluminum outer sleeve, the frm is on the inside
Every single ductile iron sleeve has a machined outer diameter, perfectly smooth... just Google a picture
Old Jan 11, 2013 | 08:24 AM
jamescannondale's Avatar
I love my Prelude, I just buy my Honda Engines from http://www.usedjapanmotors.com. They also have a new website dedicated to Honda Motors, it is http://www.allhondaengines.com
