B16 Jrsc gaskets?
Old Jan 19, 2013 | 09:26 AM
98b16sc's Avatar
Icon2 B16 Jrsc gaskets?
I ave a b16 with a jrsc setup on it the intake manifold was bad and now I want to replace all the gaskets but the descriptions on supercharger.com suck. Is it ok to use permatex? My supercharger to intake gasket is plastic and about 1/4 inch thick should I replace it with permatex? The gasket has wear on it.
Old Jan 19, 2013 | 09:49 AM
TGonie's Avatar
Default Re: B16 Jrsc gaskets?
buy a new intake manifold gasket, id recommend a hondata one, or something similar
http://www.hondata.com/heatshieldgasket.html
And for the supercharger to manifold gasket just pick up some gasket material from napa or partsource or someplace and make your own like I did when I had my jrsc. Just use a razor blade or utility knife. Works great. Just be sure to get all the little danglies off so they dont go into your engine
Old Jan 19, 2013 | 12:44 PM
MRGRIM's Avatar
R.I.P. Mark
simple answer to all
TB to s-tube = gasket "no sealant"
s-tube to charger = permatex ultra grey "no gasket"
charger to manifold = permatex ultra grey "no gasket"
manifold to head = Hondata gasket with permatex ultra grey
Gaskets on the charger to manifold breakdown and leak very easy
Im at 14psi with no leaks
just use a very thin smear when applying
Old Jan 19, 2013 | 01:32 PM
Spawne32's Avatar
they dont break down if your using the right kind of gasket
Old Jan 19, 2013 | 02:24 PM
98b16sc's Avatar
How do you get the s/c to bolt up with the intake and not smear the silicone
Old Jan 19, 2013 | 04:03 PM
Spawne32's Avatar
drench it in silicone :rollseyes:
Old Jan 19, 2013 | 04:13 PM
wantboost's Avatar
Who is Mr Robot?
Keep the thermal gasket you have and use the permatex or hondabond which is what I prefer
Old Jan 25, 2013 | 06:16 AM
98b16sc's Avatar
Why permatex on the hondata gasket? All of it or just where coolant tuns thru it?
Old Jan 25, 2013 | 11:49 AM
wantboost's Avatar
Who is Mr Robot?
Because the gasket doesn't compress like a normal gasket and imperfections on the head and manifold flange mean it might not seal completely
Old Jan 25, 2013 | 01:39 PM
MRGRIM's Avatar
R.I.P. Mark
^^^ as wantboost said ...spot on
Old Jan 25, 2013 | 01:50 PM
Spawne32's Avatar
The gasket does compress some, that's why there are indentations in it after you remove it, around the coolant outlet i could see but ive never had a problem with gasket sealing. It's not under pressure most of the time, its under vacuum. Even then I don't think it would be a problem under boost. At least ive never heard it being a problem. Using gasket maker as a replacement for proper sealer is a nightmare waiting to happen, it squeezes out on both ends in and around the ports and makes a complete mess of things.
Old Jan 25, 2013 | 02:48 PM
wantboost's Avatar
Who is Mr Robot?
I would lay a small bead around each port, like 1/16 of an inch in size, far enough from the port that it wouldn't go anywhere. Similar to how people put a dab of Honda bond around the vc gasket where it curves, since that area can can flex. It's something we do on our sr20 motors as well, since we normally run huge pressure levels and beat on the drive train hard when we go street drifting and such
That just insures a positive seal, it would suck to have to take it back off and seal it up. I'm not talking about covering the whole thing on sealer, like icing on a cake lol. That would be a huge mess.
Bsharpe
Aug 10, 2010 02:49 PM
tronic
Jan 7, 2008 06:19 PM
TAGURIT
May 8, 2004 09:46 AM
BringIT
Dec 1, 2003 06:28 AM
MADEINIRAQ
Aug 23, 2003 11:29 AM
