Headgasket issues
Old Jan 6, 2013 | 01:34 PM
QwkD16's Avatar
Default Headgasket issues
Just wondering if any of you guys have solved any "blowing the headgasket" problems by going with a .5mm over bored hg? I have an built 87mm h22a4 closed deck, 6266 running 26 psi in 4th, 1200cc injectors, s300 and boost-by-gear. The tune is spot-on...11.5's across the board and really conservative timing, so please no "you need to have it tuned" replies...its not the tune. It actually does perfect for months on end, its just a random thing. It has no overheating issues or anything, just a missfire when it happens....I can actually tell when it has happened now. I was going to order the new S.S. JE ProSeal Headgasket but they dont make one for an h series yet. Any positive info would be appreciated. Thanks in advance.
Old Jan 6, 2013 | 01:44 PM
SiRCiviC94's Avatar
Default Re: Headgasket issues
I could be wrong but with that much pressure you may need to Oring the head? or block.
Old Jan 6, 2013 | 01:47 PM
Spawne32's Avatar
Yeh, by not running a .5mm over bored headgasket lol all aftermarket head gaskets (besides custom bore gaskets) are designed to allow for .020(.5mm) over bores.
Use one of the following...
FEL-PRO Part # 26411PT
VICTOR REINZ Part # 54241
Old Jan 6, 2013 | 01:48 PM
Spawne32's Avatar
That would depend entirely on the amount of horsepower he is making.
Old Jan 6, 2013 | 01:54 PM
QwkD16's Avatar
I was wondering if that .5mm over cut gasket would help tuck away the edge of the gasket and give it like a "buffer" area?
Old Jan 6, 2013 | 01:55 PM
QwkD16's Avatar
Its close to 550-600hp
Old Jan 6, 2013 | 01:57 PM
Spawne32's Avatar
Most of the problems with overbored gaskets occur with how much material there is in-between the cylinders. It's the same concept when you over bore the block itself, you take away from the material on the joint between the cylinder walls, making it more likely to fail at the thinnest point. Do you know where exactly your gasket is failing?
Old Jan 6, 2013 | 01:58 PM
Spawne32's Avatar
Realistically you should be looking at o-ring's, IMO.
Old Jan 6, 2013 | 01:59 PM
QwkD16's Avatar
Ive been using the stock Honda headgasket. And it seems that its right on the edge. It always as a small burnt area on the edge every time
Old Jan 6, 2013 | 02:02 PM
QwkD16's Avatar
Damn... I kinda figured that. I guess I might have been in denial. lol
But ive seen several setup pull about that much on a stock gasket. Idk really. I guess its right on that edge of needing to do something different
Old Jan 6, 2013 | 11:02 PM
mechanix619's Avatar
There is no need to o-ring for your application.
Are you sure nothing is wrong with your heads studs? As in, they are bad or the holes are bad. Also, is the head and block in spec?
Stick with what works, OEM gasket/Golden Eagle.
Posted from Honda-tech.com App for Android
Old Jan 6, 2013 | 11:23 PM
gringotegra's Avatar
What does your head gasket surface look like? (head and block side)
Can you feel any grit with your fingernail?
Old Jan 7, 2013 | 09:50 AM
N_A_Power's Avatar
You don't need o-rings for that power. Start looking elsewhere.
Bent block or head or even a sunken sleeve(which can be minimal).
Old Jan 7, 2013 | 11:52 AM
SiRCiviC94's Avatar
check flatness. copper spray new gasket. go at it again lol.
Old Jan 7, 2013 | 12:30 PM
I'm not a fan of copper spray. In terms of using a sealant on the headgasket, less is always more. Just use a very light amount of RTV sealant or Hondabond on the key areas outline in the Helms manual.
Also, no sealant is going to prevent a head gasket from blowing, this OP has a larger issue at hand.
Old Jan 7, 2013 | 12:58 PM
Spawne32's Avatar
you should never need to put anything on a MLS head gasket, and ill stand by that for as long as i continue to build engines. There is a specific reason they are coated in viton and you shouldn't try to interfere with that, this isnt the 1960's.
Old Jan 19, 2013 | 11:58 AM
QwkD16's Avatar
This block is an FRM closed deck so I dont have sleeves to sink, and the last time I had the head off I straight edged it with feeler gauges and it is still flat from the last resurface. I was reading that the head and block surface need to have a certain RA (Roughness Area), and not a real slick/smooth surface. A place for the hg to grab I guess. Kind of like sanding/priming is to car paint. So I will look at that too.
Old Jan 19, 2013 | 12:26 PM
wantboost's Avatar
Who is Mr Robot?
Are you sure the head isn't lifting? High HP/boost level sohc's love to lift heads
Old Jan 19, 2013 | 12:38 PM
SiRCiviC94's Avatar
im curious what cures this set up myself
91-lsvtecsi
Aug 4, 2013 06:53 PM
Mo_Spec
Jun 24, 2010 11:05 AM
85mmek9
Sep 23, 2009 12:38 PM
Jay_Sensing
Mar 12, 2006 04:56 PM
swlabhot
May 23, 2003 11:09 AM
