310cc ingectors on stock boost
Old Feb 1, 2013 | 09:31 AM
jestin91's Avatar
Default 310cc ingectors on stock boost
het ht im putting a turbo kit next week and its a stock b20b with rc310 ingectors and a bwr regulater as well as greddy fuel mangement will that be ok for now or will it run to lean i plan on 7 psi on a t25 turbo
Old Feb 1, 2013 | 09:44 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: 310cc ingectors on stock boost
Do you really want to be limited because your injectors are maxed out. You need to be more focused on your hp goal and not psi. I imagine a b20 your only looking for about 250 so I would prob to with 550 so you have some room to grow. I just bought injector dynamic 1000 injectors for my 300hp turbo gsr build so I have room to grow when I sleeve my other block and go for 500hp. ID injectors would be the only brand I would recommend such a large injector for a low hp build like yours and mine due to the superior spray pattern and atomization of fuel.
Old Feb 1, 2013 | 10:02 AM
jestin91's Avatar
well i do want to upgrade but will the 310 be ok for now like a mounth or so
Old Feb 1, 2013 | 10:31 AM
EsotericImage's Avatar
Retired Moderator
no they wont be ok. not in the beginning, not later on. go for at least 440's
your power range for the small turbo and around 7lbs will net you around 160-170.
Your going to get bored of your power range and want to up the boost later on. so get the 440's and call it a day.
Old Feb 1, 2013 | 11:15 AM
jestin91's Avatar
Ok I understand to get 310 at least 440 but I already got the 310s with the Greddy fuel mangment box that is y said will it be ok for that bit of time till I buy different injectors
Old Feb 1, 2013 | 11:26 AM
boosted_D's Avatar
From what I can gather,
You are planning on using basically a greddy turbo kit right?
**EDIT** seems the b series greddy kits came with an 18G turbo, not a t25, maybe it was the d series that came with a t25 turbo.
None the less, they DID use 310cc injectors, so that is what you would want to use with a greddy blue box piggy back, if nothing else, a t25 is smaller than an 18G, so if that piggy back ecu is for a b series, it will actually run richer than it should with a t25, not lean.
They came with a t25 turbo at about 7 psi, and came with 310cc injectors and a pre programmed greddy blue box for managment.
If this is the case, and you are using a blue box, you do want to use the 310cc injectors, as that is what the blue box is tuned for, any other size injectors will not run properly.
Its not the best set up ever, but it should get the job done temporarily if thats what you have for now.
The blue box was designed to run with 310's, so it shouldnt go lean, as long as you are running a t25 like the greddy kits came with, and you are running low boost like a greddy kit did.
If you decide to upgrade everything to make more power, you will need bigger injectors, a different engine management set up than the blue box, like a chipped ecu with crome, neptune etc. and a dyno tune, as the blue box is a pre tuned piggy back, other forms of management need to be tuned by a professional.
Also your t25 turbo wont get you much past mid 200's for whp, but will still be a fun street car even at 250whp.
Old Feb 1, 2013 | 12:56 PM
jestin91's Avatar
Ok thank u that's wat I wanted to know but the turbo is a garet turbo
Old Feb 6, 2013 | 04:22 AM
jestin91's Avatar
Ok I got the whole kit which comes with the evo 18g turbo ill still be good at 7psi
Old Feb 6, 2013 | 08:54 AM
grumblemarc's Avatar
The Grumpiest
No such thing as an Evo 18g if I recall.
Old Feb 6, 2013 | 09:07 AM
TheShodan's Avatar
Moderator
It works for something that small. I used those years ago. They were only good to about 260whp. after that it was time to change out.
Old Feb 6, 2013 | 10:22 AM
DirtyDA9's Avatar
Yea no such thing.
Old Feb 6, 2013 | 10:51 AM
TheShodan's Avatar
Moderator
The 18G is a Garrett/Mitsu Hybrid. T25 flange, with an 18G compressor wheel and GT2860RS exhaust wheel. This is where the confusion may be.
Old Feb 7, 2013 | 03:53 AM
jestin91's Avatar
Yea it's comes in the evo8 I think
Old Feb 7, 2013 | 07:40 AM
scottdh20's Avatar
i'd say no on a b-series.
my first turbo setup was a d15b7 with a gt17 on 15lbs....maybe 180-200whp. in crome the injectors were at like 95% duty cycle at 6500rpm readline on stock fuel pressure....
grab some dsm 450's
Old Feb 8, 2013 | 03:15 PM
2fast4uhonda's Avatar
Your asking for trouble if you ask me. Do it right, not twice
Old Feb 8, 2013 | 08:04 PM
DirtyDA9's Avatar
Nope, evo 8 just has a backwards *** 16g with a larger turbine housing.
Old Feb 8, 2013 | 09:41 PM
wantboost's Avatar
Who is Mr Robot?
No it doesn't, Greddy kits are old... like 1990s old
The evo8-9 have a TD05HRA-16G6.... which is nothing like the Greddy turbo.
Old Feb 8, 2013 | 09:42 PM
wantboost's Avatar
Who is Mr Robot?
grab some dsm 450's
That actually sounds like tons of fun... I have a gt17 laying around too... hmmm
Old Feb 9, 2013 | 01:52 PM
vtechjunkie's Avatar
I liked my car with the 310's in it. After all passing 300whp too much, on the street really just makes traction more of an issue. I say if it's a street car, and 250whp is ok for you, then sure, use them. If you want to go for more some time, then go bigger. Easy.
Old Feb 9, 2013 | 02:20 PM
wantboost's Avatar
Who is Mr Robot?
^exactly
They work for what you have now and are a drop in solution given that you have the pre tuned blue box..
While not the best solution as your location differs from where the tune was created.. so elevation, humidity, ambient temp, and the fact that no two identical setups will run the same on an identical tune... I would really at least use a chipped ecu and have it tuned
But the blue box, 310s and standard Greddy boost levels will work fine.
Old Feb 10, 2013 | 08:37 AM
DeeC2's Avatar
10 Year Member
Icon3 Re: 310cc ingectors on stock boost
this is all BS they will be ok if you get your car tunned
Old Feb 10, 2013 | 08:40 AM
DeeC2's Avatar
10 Year Member
Yes, and alot longer than a month also. My friend has been on 310 for about 5 years now and his car is quick!
92civic4drb18b1
Jun 21, 2011 08:39 AM
jamesfawcett
Apr 13, 2010 01:33 AM
chrisfromsrq
Oct 4, 2009 04:19 PM
boostcrazy1234
Apr 14, 2008 10:19 AM
DriveSlowHomie
Feb 18, 2005 11:59 AM
