Could this be why iam getting to much oil int the turbo??
Iam using a braded hose that has quater inch fittings?
Where do i buy restricter valves for a quater inch female end> for my feed line
Re: Could this be why iam getting to much oil int the turbo?? (seeeya04)
what size feed/return line's are they? 3AN feed and 10AN return are the standard sizes you would typically see
Re: Could this be why iam getting to much oil int the turbo?? (SSBPGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR »</TD></TR><TR><TD CLASS="quote">what size feed/return line's are they? 3AN feed and 10AN return are the standard sizes you would typically see </TD></TR></TABLE>
That is correct! those are the sizes you will need! If you are using 1/4" on the return side that is no good!
Re: Could this be why iam getting to much oil int the turbo?? (tallyturbo)
http://www.atpturbo.com sells restrictors
boost fed ls
08-01-2003 12:20 AM
