rebuilding a b18a1
Old Dec 12, 2005 | 03:09 PM
iguano's Avatar
Default rebuilding a b18a1
hi, some friend of mine have just give me a turbo 16g mitsubishi, it includes the westgate, i already hace the BOV ( from a stock 2002 wrx) and i bought a walbro 255 fuel pump, i know that i am missing some parts but my problem is that my car have 104k miles....... i want to rebuild my engine, but i dont know exactly the parts that i need and the best brands..... i think that i need: all the gaskets and seals, pistons, rings, rods, bearing, new oil pump (the water pump its new) timing belt...... what else do i need, do you guys recommend the forged pistons and rods? how more expensive are???.....
im too new on this so if you guys can help i´ll really appreciate!!!!
thanks!
Old Dec 12, 2005 | 03:21 PM
520_Motorsports's Avatar
Default Re: rebuilding a b18a1 (iguano)
If you are boosting than I would olny used forged internal such as pistons and a good set of rods. I recommend CP Pistons and the new Eagle rods w/ 3/8 rod bolts. You don't have to use forged internals but its recommended. As for prices ask Earl from Laskey racing. I would buy a complete engine gasket kit and new OEM oil pump. PLEASE get a good engine management so you don't blow your money building this engine and F it all up with a crappy E/M. As for the rest of your turbo stuff check my sig below and contat the guys at phoenix turbo!
Old Dec 12, 2005 | 03:22 PM
Default Re: rebuilding a b18a1 (SlowAzEg)
Also get a good set of dual valve springs you dont want to ruin everything by dropping a valve!!!!!!!!
Old Dec 12, 2005 | 03:48 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowAzEg &raquo;</TD></TR><TR><TD CLASS="quote">Also get a good set of dual valve springs you dont want to ruin everything by dropping a valve!!!!!!!! </TD></TR></TABLE>
only if you have cams/headwork and plan on revving past 7500. ive taken my beat *** stock ls head to 7500 many times and no probs. much above that and it goes downhill.
eagle rods and some forged piston (je, arias, wiseco, cp). go oem for bearings and gaskets. then u are done. oh arp headstuds help nicely. now youve got a 350-400whp capable motor.
Old Dec 12, 2005 | 06:34 PM
iguano's Avatar
Default Re: rebuilding a b18a1 (blackeg)
thank you very much for all the answer, but wich is a good store to check the prices, and another question, what exactly does the engine management do, and what do you thik about using a fmu?????
thanks again!
ahhhhhh, my car is a integra 93
Old Dec 12, 2005 | 06:55 PM
SOHCD16y8's Avatar
If your going to spend all that money building a motor why would you risk it with an FMU?
Get uberdata or crome and a wideband. Youll be happy.
Old Dec 12, 2005 | 07:02 PM
blackeg's Avatar
Default Re: (SOHCD16y8)
hmm, i hate fmu's, but that doesnt mean they arent very good for specific applications:
low boost like 6 or 7 psi, you can run colder plugs and take about 2 degrees timing out of the dist. and be perfectly fine on an ls due to its lower compression. i recommend getting a rising rate one.
however, if u are paying money for aftermarket motor parts, get real management that you can program using your computer. this would include hondata, uberdata, chrome, etc...
the management controls fuel (you will need larger than stock fuel injectors if you run stock fuel pressure), and depending on which one you get, it should control ignition timing and many other things like redline etc...
MikeChally
Nov 10, 2011 03:27 PM
blackccoupe
Sep 28, 2009 09:57 AM
JacobMagner
Jul 11, 2008 01:20 PM
buckfittyone
Apr 22, 2003 07:32 AM
BlueSi2k
Jul 31, 2002 09:14 PM
