Will this turbo support my goal of ~300whp??? Need to know soon....going to buy!!
Man U FTW
I'm going to buy a turbo over my Christmas break from college and i want to make sure this turbo is going to fit my needs before i go and buy it.
I'm looking at a T3/T04E 57Trim .63 AR
Is that going to be big enough to support 300whp on a STOCK motor GSR???
Re: Will this turbo support my goal of ~300whp??? Need to know soon....going to buy!! (Schister66)
Yes that turbo can make 300WHP...as long as you tuner knows what they are doing.
Man U FTW
i'm looking for something around 300whp, doesn't have to be that high because i want to make power at like 3500-4500rpm and have full boost by 5000 or a little over.
What do you think is possible and safe for this turbo and the stock engine??
Do you think i should cut down my power goals a little??
Re: (Schister66)
The turbo can support 300WHP and like adseguy pointed out it is good for up to 400-450WHP if you want to push it harder. 300hp should be around 9-10 psi for that turbo. If you wanted to you could also go with a 50 trim or 54 trim T04E which might be a little more efficient then the 57 trim. For lag I've seen people say anywhere between 5000-5500 RPM's. But if you want really good spool you could get a 0.48 ar turbine instead of the more common 0.63 ar turbine. But you'll sacrifice your high end for better low end performance with a 0.48 turbine.
EDIT: You should probably be more concerned with blowing the stock block instead of shooting for 300 WHP. To keep it a little safer you could run less boost and stick with 250ish WHP.
