Need a tip on how to remove rod caps..
Old Dec 11, 2005 | 01:07 PM
Dublocivic's Avatar
Default Need a tip on how to remove rod caps..
I am in the middle of rebuilding my short block and I was curious if anyone had some good ideas on how to remove rod caps with out the crank spinning and distorting my plastigauge readings.... anyone?
Thanks
Old Dec 11, 2005 | 01:13 PM
Boner_Ben's Avatar
I usually just loosen both rod bolts but not pull them out. Then tap on the bolt heads with a mallet and that pulls them off the dowels.
Old Dec 11, 2005 | 01:37 PM
Dublocivic's Avatar
Default Re: (Boner_Ben)
That works. Thanks
Old Dec 12, 2005 | 03:24 PM
SSBPGSR's Avatar
Default Re: Need a tip on how to remove rod caps.. (Dublocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">I usually just loosen both rod bolts but not pull them out. Then tap on the bolt heads with a mallet and that pulls them off the dowels. </TD></TR></TABLE>
x2
excellent technique
Old Dec 12, 2005 | 04:38 PM
Importordomestic's Avatar
x3
Old Dec 12, 2005 | 04:44 PM
SOHCD16y8's Avatar
x4 lol
Old Dec 12, 2005 | 05:02 PM
SSBPGSR's Avatar
Default Re: (SOHCD16y8)
haha damn, mad engine builders!
Old Dec 12, 2005 | 05:52 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
thats pretty much what i do..but i use a small punch that fits in the dimple of the bolt and lightly tap it..
Old Dec 13, 2005 | 04:52 PM
m R g S r's Avatar
Default Re: (SSBPGSR)
i caress and stroke the rods, they get so excited they pop the caps right off!
Old Dec 13, 2005 | 05:46 PM
blackeg's Avatar
Default Re: (m R g S r)
i use the mallot then finesse technique.
89s1
Jan 12, 2008 05:56 AM
Toadfart
Nov 14, 2005 09:29 PM
importboi22
Nov 5, 2003 07:24 AM
BlueSi2k
May 4, 2003 07:49 PM
VWkila
Apr 11, 2003 10:44 PM
