ECU already socketed, is it ready for datalogging???
Old Dec 12, 2005 | 09:31 PM
See Are X's Avatar
Default ECU already socketed, is it ready for datalogging???
I bought a ECU thats been socketed already...im just gonna buy a usb cable from radio shack, do I need to do anything else to the ECU to datalog?
Old Dec 13, 2005 | 06:00 AM
93turbo16's Avatar
Default Re: ECU already socketed, is it ready for datalogging??? (See Are X)
For most programs you have to remove the jumper at <U>J12</U>and add a 4-pin datalogging header at the CN2 port.
Modified by 93turbo16 at 10:50 AM 12/13/2005
Modified by 93turbo16 at 10:51 AM 12/13/2005
Old Dec 13, 2005 | 06:02 AM
Jim Truett's Avatar
Default Re: ECU already socketed, is it ready for datalogging??? (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">For most programs you have to remove the jumper at J1 and add a 4-pin datalogging header at the CN2 port.</TD></TR></TABLE>
That's the jumper at J12 that allows full duplex operation.
Old Dec 13, 2005 | 06:50 AM
93turbo16's Avatar
Default Re: ECU already socketed, is it ready for datalogging??? (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
That's the jumper at J12 that allows full duplex operation.</TD></TR></TABLE>
That is what I meant.
Old Dec 13, 2005 | 07:29 AM
97CWITR's Avatar
More simple terms would be appreciated!
This is directly on his ecu im assuming, at jumper J12 and CN2
4 pin datalogging header?
Old Dec 13, 2005 | 07:35 AM
93turbo16's Avatar
Yes, Take out the jumper resistor.. has a black stripe on it, and insert a 4pin header at CN2. I will try to find some pics.
Old Dec 13, 2005 | 07:42 AM
Everyones Hero's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, Take out the jumper resistor.. has a black stripe on it, and insert a 4pin header at CN2. I will try to find some pics.</TD></TR></TABLE>
I'd appreciate it.
I've got to go back and find the threads so I can find out what cable to get again.
Old Dec 13, 2005 | 08:02 AM
93turbo16's Avatar
The cable attaches to a 4-pin header at the CN2 port. Just look to the left of the middle casing and look for a resistor called J12, it is white with a black stripe. Just desolder that.
Old Dec 13, 2005 | 08:13 AM
97CWITR's Avatar
ahh i gotcha
this is the only thing that needs to be done for OBDI ecu's for datalogging?
Old Dec 13, 2005 | 08:17 AM
Where can you get a 4-pin header? I think one had come with my uberdata kit, but I wasn't sure what to do with it and now I've lost it.
Old Dec 13, 2005 | 08:20 AM
93turbo16's Avatar
you can get one from digikey. I gotta find the part number.
It is
A1922-ND
http://www.digikey.com
Old Dec 13, 2005 | 08:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">you can get one from digikey. I gotta find the part number.
It is
A1922-ND
http://www.digikey.com</TD></TR></TABLE>
Thank you.
What do you have to get for the end of the cable so that it'll plug into that correctly?
edit: I've been thinking of the USB way of doing it, not through the COM ports. It should be essentially the same, though.
Old Dec 13, 2005 | 08:42 AM
93turbo16's Avatar
check out http://www.moates.net
the hulog should have everything you need.
Old Dec 13, 2005 | 08:56 AM
thanks again.
Just a matter of how soon I find a laptop to use will determine when I'll actually set everything up.
Old Dec 13, 2005 | 08:57 AM
servion's Avatar
Has anyone identified another cheap datalogging cable thats easily available now?
I really miss the days of the $10 radioshack nokia USB cable for datalogging; I bought all the ones up in my area and now they're gone I've found one thats around $25 that should work...
Old Dec 13, 2005 | 08:58 AM
Default Re: (servion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone identified another cheap datalogging cable thats easily available now?
I really miss the days of the $10 radioshack nokia USB cable for datalogging; I bought all the ones up in my area and now they're gone I've found one thats around $25 that should work...</TD></TR></TABLE>
I remember seeing some guy on ebay selling them for $10 or $15. Why did they stop selling them?
servion's Avatar
They are now discontinued... I'm not sure why though
Old Dec 13, 2005 | 08:59 AM
blundar's Avatar
Supposedly, some of the Sanyo cables work. I'm not 100% sure though... Either my Prolific 2303 drivers got corrupted (entirely possible) or those cables don't work worth a ****. If you're going to spend $25, might as well get a USBMOD2/USBMOD3 with the FTDI bridge chip - it's infinitely better. (Or a Moates HUlog, etc.)
Old Dec 13, 2005 | 09:03 AM
servion's Avatar
Default Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar &raquo;</TD></TR><TR><TD CLASS="quote">Supposedly, some of the Sanyo cables work. I'm not 100% sure though... Either my Prolific 2303 drivers got corrupted (entirely possible) or those cables don't work worth a ****. If you're going to spend $25, might as well get a USBMOD2/USBMOD3 with the FTDI bridge chip - it's infinitely better. (Or a Moates HUlog, etc.)</TD></TR></TABLE>
Do you have any info on where such a kit can be found? I know of the Moates kit and the xenocron kit thus far...
Old Dec 13, 2005 | 09:11 AM
blundar's Avatar
ask google... they're demo modules for the FTDI USB bridge chips that Moates, Hondata, etc. use. I believe Saelig sells them (http://www.saelig.com)
Old Dec 13, 2005 | 09:16 AM
SilCiv2K's Avatar
Default Re: nokia cable
i have one of the nokia usb cables laying around, 20 shipped to your door. pm
Old Dec 13, 2005 | 12:33 PM
See Are X's Avatar
Default Re: nokia cable (SilCiv2K)
I just went ahead and bought the HULOG from moates.net. This thing comes with a 4-pin header for the CN2 connection right???
Old Dec 13, 2005 | 12:40 PM
Default Re: nokia cable (See Are X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">I just went ahead and bought the HULOG from moates.net. This thing comes with a 4-pin header for the CN2 connection right???</TD></TR></TABLE>
It doesn't look like it.
If it doesn't and you don't want to order a header you can cut the wires and just solder them into the board. Only downfall is that you won't be able to disconnect the cable when you're done with it.
Old Dec 13, 2005 | 01:33 PM
BlueShadow's Avatar
Default Re: nokia cable (Everyones Hero)
Just wanted to point something out with the J12 dealio. If you are using Uberdata you do not cut the jumper at J12. If you are using CromePRO then you need to cut J12. If you are using Hondata I *think* you also have to cut J12, but I'm not 100% sure. I dont know what you have to do for Turboedit, Neptune, or the free datalogging software (I think it's called?)
Old Dec 13, 2005 | 01:41 PM
93turbo16's Avatar
Default Re: nokia cable (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to point something out with the J12 dealio. If you are using Uberdata you do not cut the jumper at J12. If you are using CromePRO then you need to cut J12. If you are using Hondata I *think* you also have to cut J12, but I'm not 100% sure. I dont know what you have to do for Turboedit, Neptune, or the free datalogging software (I think it's called?)</TD></TR></TABLE>
Uberdata is the only software that requires J12, but I have actually had it working fine with it removed too, atleast I think.. But hondata does require it to be removed.
