Dyno: Boosted B16
Old Dec 9, 2005 | 11:04 AM
aalb1's Avatar
Default Dyno: Boosted B16
T3/TO4E 54 trim .63a/r
RLD Manifold & 3" DPhttps://honda-tech.com/zerothread?id=1105639
Tial 38mm WG
3" Thermal Exhaust
2.25" Custom Charge Piping
CCA Intercooler
HKS BOV
Victor X Manifold
450cc Marren Injectors
3bar map sensor
Walboro 255lph fuel pump
Skunk2 Adjustable Cam Gears
10 PSI on NepTune
All this on a Bone Stock B16 Head & Block
Post your thoughts or comments below...
Modified by aalb1 at 12:23 PM 12/9/2005
Old Dec 9, 2005 | 11:16 AM
99lspwr's Avatar
Default Re: Dyno: Boosted B16 (aalb1)
How much boost??
Old Dec 9, 2005 | 11:20 AM
aalb1's Avatar
Default Re: Dyno: Boosted B16 (99lspwr)
10psi
Old Dec 9, 2005 | 11:28 AM
99lspwr's Avatar
Not bad ... What kind of total timing are you running at that level on a stock b16??
Old Dec 9, 2005 | 11:31 AM
Benjithx's Avatar
Old Dec 9, 2005 | 11:32 AM
11psiTurboSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">Not bad ... What kind of total timing are you running at that level on a stock b16??</TD></TR></TABLE>
Like to know this too!
Old Dec 9, 2005 | 12:00 PM
aalb1's Avatar
Default Re: Dyno: Boosted B16 (11psiTurboSI)
I'm at work right now and I don't know...I'll let you know when I'm home.
Old Dec 9, 2005 | 12:04 PM
RobbieG35's Avatar
12 Years Strong
Looks good. I love my RLD manifold, how is yours doing?
Old Dec 9, 2005 | 12:17 PM
Sketch_hs's Avatar
looks pretty laggy
how does it feel on the street?
Old Dec 9, 2005 | 01:37 PM
97CWITR's Avatar
Default Re: (Sketch_hs)
disapointed with the spool on the .57 trim , .63 a/r! Power only coming on at 6000rpm, even with a 3" exhaust....
Is this a daily driver?
Old Dec 9, 2005 | 01:38 PM
DriveSlowHomie's Avatar
nice numbers...bump cause i have the same exact turbo
Old Dec 9, 2005 | 01:50 PM
s2kkk's Avatar
Not to shabby. I put down 325 on my stock B16 with CTR cams and adjustable cam gears. The adjustable cam gears make a world of difference. I too was at 10PSI.
Old Dec 9, 2005 | 03:19 PM
EK_GSR's Avatar
Default Re: (spoon.eg)
well that is a bone stock head VS. CTR cams.... that on its own makes a HUGE difference.....
Old Dec 9, 2005 | 04:02 PM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">looks pretty laggy
Old Dec 9, 2005 | 05:09 PM
SpeedingHatch's Avatar
Default Re: (12SEC CIV)
yeah, check your pipes and stuff for boost leaks
the peak seems good, but its the area under the curve that is lacking
Old Dec 9, 2005 | 05:10 PM
civicpacrat's Avatar
pretty good at 10 let me know when you enguage v-tec sooner and get to 16-20psi. good tune should hold together about 6mo's to a year. go all out a get a reason to sleeve the motor.
Old Dec 9, 2005 | 08:23 PM
B18C1CYA's Avatar
Default Re: Dyno: Boosted B16 (civicpacrat)
looks good for 10psi , ditch that .54 trim and you will be good
Old Dec 10, 2005 | 12:18 AM
s2kkk's Avatar
I was running a 60-1 turbo. FR STAGE2 kit.
Old Dec 10, 2005 | 12:00 PM
See Are X's Avatar
Old Dec 10, 2005 | 12:29 PM
SSBPGSR's Avatar
Default Re: Dyno: Boosted B16 (See Are X)
im going to guess and say the timing was pretttty conservative. who tuned it with neptune?
Old Dec 10, 2005 | 01:09 PM
aalb1's Avatar
Default Re: Dyno: Boosted B16 (SSBPGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">im going to guess and say the timing was pretttty conservative. who tuned it with neptune?</TD></TR></TABLE>
This was tuned by Jeff Evans and timing is at 14*. Jeff would probably be the first to label himself as a conservative tuner...extremely competant but conservative too.
It seems that my engine never breathed that well. I'm sure the b16 cams add to the problem. You can see that little dip right around 6750 rpms. There was a similiar dip like that on my first tune (not by Jeff). Jeff spent about an hour and a half just trying to fix that dip but to no avail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah, check your pipes and stuff for boost leaks
the peak seems good, but its the area under the curve that is lacking</TD></TR></TABLE>
No leaks... Also to address your "area under the curve" comment I told Jeff to try to tune for all power to be up at the top. With the gearing of an SI Tranny that power is where it's suppose to be when I go down to the track... too bad I haven't made it down to the track yet
how does it feel on the street?</TD></TR></TABLE>
Mos Def... I am second guessing if I should try to shift down the power band on my next tune. If so that means Victor X should probably go.
Old Dec 12, 2005 | 12:48 PM
StockBlockRob's Avatar
not bad power but seems kind of weak for the tuner and the set-up I would expect more into the low 300's
Old Dec 12, 2005 | 01:22 PM
B18C1CYA's Avatar
Default Re: Dyno: Boosted B16 (vtecrob16a)
it is a .54 trim turbo , they suck i used to run one , they blow , mine made 325whp at like 1 bar , the turbo is week ,
Old Dec 12, 2005 | 01:27 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aalb1 &raquo;</TD></TR><TR><TD CLASS="quote">This was tuned by Jeff Evans and timing is at 14*. Jeff would probably be the first to label himself as a conservative tuner...extremely competant but conservative too.
I find it hard to believe that he would set your total timing at 10psi to only 14*. That must have been your timing set at the distributor?
Day-DayC
Sep 25, 2006 08:18 AM
Meet07
Feb 1, 2006 10:05 AM
XxRoCkMaNxNEOxX
Sep 5, 2005 01:16 PM
carboy247
Jun 18, 2005 11:51 PM
B16Drag
Dec 24, 2003 09:27 AM
