Does a 3" exhaust really make that much of a difference?
Old Dec 11, 2005 | 03:02 PM
GetawayInMoscow's Avatar
Default Does a 3" exhaust really make that much of a difference?
Here is the deal, I am piecing together a turbo kit for my civic (jdm b16, t3/t4e). I have the option of spending a lot more money for a 3" downpipe and 3" exhaust, or just get a 2.5" downpipe and stick with my mandrel bent 2.5" exhaust.
I plan on making 260-280whpish if that helps.
So do you think the extra money for full 3" is worth it?
Old Dec 11, 2005 | 03:08 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Does a 3" exhaust really make that much of a difference? (GetawayInMoscow)
yes
BB6-213's Avatar
yes it is, just get the setup from kteller, its like $200 for the full 3" piping in sainless.
Old Dec 11, 2005 | 03:14 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (BB6-213)
I'd say stick with 2.5" for your power goals.
Old Dec 11, 2005 | 03:41 PM
2SLO's Avatar
Default Re: (boostincoupe)
my 3 inch is quiter than my nasty farts.
Old Dec 11, 2005 | 06:32 PM
bubs's Avatar
If it were me and I already had a full 2.5" exhaust, I'd save my money and stick with it for that power level. The 3" may give a slightly better spool time, but I doubt it will be too noticeable. You could always get the 3" downpipe now to attach to your 2.5" exhaust and upgrade your current piping to 3" later on if you decide to run more boost.
Old Dec 11, 2005 | 06:35 PM
B18C1CYA's Avatar
Default Re: (bubs)
If you have a 3" downpipe you will loose power by stepping it down to a 2.5" exhaust, i would go 3" , you will be better off
Old Dec 11, 2005 | 06:36 PM
hotimportcrx's Avatar
Default Re: (bubs)
i would run 2.5 inch on a daily driver because its really quiet....but get an e cutout so when you up the boost for a race...you can run open 3 inch downpipe
Old Dec 11, 2005 | 07:39 PM
EVIL Hx Coupe's Avatar
Default Re: (hotimportcrx)
For your power goals 2.5" is enough. You should be able to make 280whp with no sweat.
Old Dec 11, 2005 | 07:44 PM
dunkd's Avatar
stick with what you got if its just gonna be stock motor.
Old Dec 11, 2005 | 07:46 PM
jfoster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">i would run 2.5 inch on a daily driver because its really quiet....but get an e cutout so when you up the boost for a race...you can run open 3 inch downpipe</TD></TR></TABLE>
I vote 3" DP with 2.5" exhaust and a 3" cut out.
Old Dec 12, 2005 | 02:05 PM
Silverbullet86's Avatar
Default Re: (jfoster)
cut outs arent the most reliable things out there. I've went through a couple.
Old Dec 12, 2005 | 02:29 PM
tallyturbo's Avatar
Default Re: (Silverbullet86)
i have the same setup and i plan on using a cutout
Old Dec 12, 2005 | 06:22 PM
yee SERIOUS's Avatar
me too. i have a 2.5 exhaust already and i'm getting an ecut out.
Old Dec 12, 2005 | 06:29 PM
m R g S r's Avatar
yup
Old Dec 12, 2005 | 06:55 PM
red_crx's Avatar
Default Re: Does a 3" exhaust really make that much of a difference? (m R g S r)
i'm running full 3 inch.....i just got tired of having the downpipe dump down. its a whol lot quiter now....but you could always do a e-cut out.
Old Dec 12, 2005 | 06:59 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
say you were boosting a stock b16 with 2.5 DP to 2.5 Exhaust , how much power would you gain going to the 3in set up DP and exhaust....like hp? i'm trying to make about the same choice
Old Dec 12, 2005 | 09:10 PM
BoostedJeff's Avatar
Default Re: Does a 3" exhaust really make that much of a difference? (DBL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBL &raquo;</TD></TR><TR><TD CLASS="quote">say you were boosting a stock b16 with 2.5 DP to 2.5 Exhaust , how much power would you gain going to the 3in set up DP and exhaust....like hp? i'm trying to make about the same choice</TD></TR></TABLE>
that all depends on other stuff, like size of turbo, what boost level, etc.
Old Dec 12, 2005 | 09:46 PM
FONK's Avatar
on my dyno at 14psi i made 360 on open down pipe andthen we bolted on my 2.5 hks hi-power i made 325 goes to show the difference
davidluko
Apr 26, 2007 10:27 AM
vg7z
Jun 2, 2006 07:01 PM
A.E Motoring
Mar 8, 2006 05:53 AM
Hoosier Daddy
Apr 15, 2004 04:15 PM
Derek14
Mar 23, 2004 09:10 AM
