cel code 45 after fuel pump install???
Old Dec 7, 2005 | 04:43 PM
scartail's Avatar
Default cel code 45 after fuel pump install???
in leu of switching over from fmu to uberdata/dsm 450s... I went ahead and changed over my intank to a walbro 255 pump last weekend. I was driving around today and got a cel code 45-lean/rich. Is this common?
My setup is t3/t4@4psi of boost in a B18B, 12:1 fmu & inline fuel pump. I wasn't beating on it or anything when it occurred. I had primed the pump several times before startup. I was driving it for two or so days before this code. I didn't smell anything unusual when this occured.
any help would be great.
Old Dec 7, 2005 | 04:57 PM
Finland's Avatar
Default Re: cel code 45 after fuel pump install??? (scartail)
It's getting more fuel now with the new pump, running rich. The O2 sensor is probably covered in soot, hence code 45. Clean the sensor and see if the code comes back. If it does, you'll probably have to change the sensor. It may be that no matter what you do with an FMU and that pump that it will run pig rich under boost, so ultimately it will end up being a tuning issue.
Old Dec 7, 2005 | 05:14 PM
scartail's Avatar
Default Re: cel code 45 after fuel pump install??? (Boondock Saint)
so if i say away from boost until i get everything setup, I should be okay right?
Old Dec 7, 2005 | 05:54 PM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scartail &raquo;</TD></TR><TR><TD CLASS="quote">so if i say away from boost until i get everything setup, I should be okay right?</TD></TR></TABLE>
Hard to say, that pump creates higher pressure than your stock pump, and the FMU creates a restriction on the return line even when not in boost, so your static fuel pressure is probably a bit higher than it should be, so a rich condition may be present even when not in boost, or even while idling. The ecu should be able to compensate for it in closed loop, but not with a contaminated sensor, that would be the first thing I'd address, then move on from there.
Old Dec 7, 2005 | 07:51 PM
scartail's Avatar
I'll give it a shot... Thanks for the info.
jaredvabeach
15
Jun 21, 2008 05:38 PM
Rikter
Sep 11, 2006 02:21 PM
triple_s1x
Dec 10, 2004 07:47 PM
BassBoy19
Dec 22, 2003 08:38 PM
OBDI JEDI
May 7, 2003 05:06 PM
