JDM d15b7 and Vitaras?
Old Dec 7, 2005 | 08:58 AM
busta's Avatar
Default JDM d15b and Vitaras?
Will they work? Some say yes some say no...some say you need to use main bearings for a d15 and rod bearings for a z6. Just wanna make sure before I go ahead with this build up.
Modified by busta at 12:52 PM 12/8/2005
Old Dec 7, 2005 | 11:29 AM
wpgcivic's Avatar
why vitaras? my bro made 264 wheel on stock engine...
Old Dec 7, 2005 | 01:47 PM
nonvtecD's Avatar
no, compression will be too low
Old Dec 7, 2005 | 09:11 PM
busta's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">no, compression will be too low</TD></TR></TABLE>
How low?
For some reason I thought that the CR would be a tad higher then a z6 with vitaras.
Old Dec 7, 2005 | 09:14 PM
busta's Avatar
Default Re: (wpgcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">why vitaras? my bro made 264 wheel on stock engine...</TD></TR></TABLE>
What are his specs? Must of had one hell of a tuner.
Old Dec 7, 2005 | 09:16 PM
_gurusan_'s Avatar
Default Re: (busta)
I can't answer your question but he has a z6 and vitaras (according to sig), and if he says it's too low then he's prolly right.
I know they are around 8.5:1 with a d16z6.....already that's way too low in my book.
Old Dec 7, 2005 | 10:07 PM
busta's Avatar
Default Re: (_gurusan_)
Anyone running vitaras in their jdm d15b? Theres got to be somebody!
Modified by busta at 12:51 PM 12/8/2005
Old Dec 8, 2005 | 03:42 AM
fjt's Avatar
fjt
Default Re: (busta)
the problem with some d15's is the stroke that is different from d16. Thats why its not as easy as just taking a Z6 rod or any other D16 rod and throw it in..
The only rods to make it work would be Going with CROWER rods which are expensive($600)
For that price you buy a D16 block,eagles and vitaras
150 for a d16 block + 300 Eagle rods + 125 Vitaras= $575
Old Dec 8, 2005 | 06:43 AM
wpgcivic's Avatar
Default Re: (busta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by busta &raquo;</TD></TR><TR><TD CLASS="quote">
What are his specs? Must of had one hell of a tuner.</TD></TR></TABLE>
sc50 turbo, home made log mani, turbosmart ultragate wastegate, 3" dp, 3" exhaust, hks hyper ti muffler, stock intake manifold, stock head and block, vortech bov, uberdata for tuning, 14 psi made 264 wheel and 200 ft tq...and yeah the tuner is really good, makes power on anything and makes everything super reliable
Old Dec 8, 2005 | 08:08 AM
nonvtecD's Avatar
I was confused, a JDM D15b is not the same as a d15b7 as you described it. In a JDM D15b motor yes the compression would be around the same as a z6, 8.5:1 or so...
Old Dec 8, 2005 | 09:53 AM
busta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">I was confused, a JDM D15b is not the same as a d15b7 as you described it. </TD></TR></TABLE>
Sorry, my bad...corrected
Old Dec 8, 2005 | 10:13 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">I was confused, a JDM D15b is not the same as a d15b7 as you described it. In a JDM D15b motor yes the compression would be around the same as a z6, 8.5:1 or so...</TD></TR></TABLE>
You still have the crap-*** short deck D15, married to the D16 rod that comes in the D15B/VTEC. CR is going to change.
Beware standard sized Vitara in a standard sized D-series bore. Excessive piston-bore gap != happy.
Old Dec 9, 2005 | 07:46 AM
busta's Avatar
Default Re: (fjt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt &raquo;</TD></TR><TR><TD CLASS="quote">the problem with some d15's is the stroke that is different from d16. Thats why its not as easy as just taking a Z6 rod or any other D16 rod and throw it in..
150 for a d16 block + 300 Eagle rods + 125 Vitaras= $575 </TD></TR></TABLE>
I thought the d15 rods were the same as the z6's
http://turbod16.com/viewtopic.php?t=20075
According to Bizzar(from the link above), everything should work...shouldn't it?
Old Dec 9, 2005 | 10:10 PM
Default Re: (busta)
I dunno if it will work, and since JDM D15B VTEC are sorta obscure around here I don't care to find out.
The rod is the same as D16, the deck height is shorter, and whether or not the G16 piston has a good compression height for the D15 block is up to someone else to determine.
I think that sums it nicely
FaceTuned
Jun 14, 2005 09:21 PM
cxhb
Jun 12, 2005 08:16 PM
drowzysleeper
Mar 29, 2005 03:00 PM
89 pos
22
Nov 21, 2004 07:03 PM
GOLDBERG
Apr 27, 2003 12:22 AM
