which crank is better for boost?
Old Dec 7, 2005 | 01:24 PM
DC2 to AP2's Avatar
Default which crank is better for boost?
i have both a ITR and a GSR crank and wondering which one would be better for boost.
thanks
Old Dec 7, 2005 | 01:36 PM
_gurusan_'s Avatar
Default Re: which crank is better for boost? (imola-red dc2)
neither is "better" for boost.
a crank is a crank
Old Dec 7, 2005 | 01:45 PM
BlueShadow's Avatar
Default Re: which crank is better for boost? (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">neither is "better" for boost.
a crank is a crank</TD></TR></TABLE>
yah, there were a few threads in the all motor forum about the ITR vs GSR crank. I dont think there's enough of a difference to matter to us FI folks. Now if it was GSR/ITR vs LS crank I would say go with the LS crank for the stroke and extra 40cc's of displacement.
Old Dec 7, 2005 | 01:48 PM
jdm94eg's Avatar
Default Re: which crank is better for boost? (BlueShadow)
what about the b20 crank is it the same as the ls?
Old Dec 7, 2005 | 01:49 PM
_gurusan_'s Avatar
There is no difference between the two, they have the same stroke....I don't know if the ITR is factory balanced making it better for higher RPM....but other then that...?:
B18C1: 1.58/137.9MM
B18C5: 1.58/137.9MM
B18C1 P72
ROD LENGTH: 5.429”
STROKE: 3.433”
BORE SIZE: 3.189” (81MM)
COMPRESSION HEIGHTS: 1.183”
DOME HEIGHT: .000”
WEIGHT: 305 GRAMS
B18C5 P73-A0
ROD LENGTH: 5.429”
STROKE: 3.433”
COMPRESSION HEIGHTS: 1.190”
DOME HEIGHT: .070”
WEIGHT: 310 GRAMS
Old Dec 7, 2005 | 01:50 PM
_gurusan_'s Avatar
Default Re: which crank is better for boost? (jdm94eg)
Yes. Here's info:
Stock Piston:
B16A PR3
B16A(JDM) P30
B17A1 P61
B18C1 (USDM) P72-A0
B18C1 (JDM) P72-00
B18C5 (USDM) P73-A0
B18C5 (JDM) P73-00
B16B PCT
B18B1 P75
B18A1 PR4
D15B1 P03
http://www.heeltoeauto.com/dse...x.jpg
D15B2 P03
D15B7 P03
D15Z1 P07
http://www.heeltoeauto.com/dse...1.jpg
D16A6 PM6
D16Z6 P28
D16Y7 P2E
D16Y5 P2M
D16Y8 P2P
D17A1 PLM-A0
D17A2 PLR-A0
ZC PM7
Stock Compression:
B16A 10.2:1 (1ST GEN)
B16A 10.4:1 (2ND GEN-UP)
B17A1 9.7:1
B18C1 10.0:1 (USDM)
B18C1 10.6:1
B18C5 10.6:1 (USDM)
B18C5 11.1:1 (JDM)
B16B 10.8:1
B18A1 9.2:1
B18B1 9.2:1
B18B 9.4:1 (JDM)
B20B 8.8:1 (USDM/JDM)
B20Z 9.6:1 (USDM/JDM)
D16A1 9.5:1
D16Z6 9.1:1
D16Y8 9.6:1
ZC 9.5:1
Engine Piston Mixing Compression output:
B16A W/ B16B(PCT) PISTONS YEILD 11.1:1
B16A W/ B18C5 (P73-A0) PISTONS YEILD 10.4:1
B16A W/ B18C5 (P73-00) PISTONS YEILD 10.7:1
SAME ORDER FOR THE REST
B17A1 11.4
B17A1 10.6
B17A1 10.8
B18C1 11.8:1
B18C1 10.9:1
B18C1 11.4:1
Piston/Rod Measurements:
B16A PR3:
ROD LENGTH: 5.290”
STROKE: 3.031”
BORE SIZE: 3.189 “(81MM)
COMPRESSION HEIGHTS: 1.180”
DOME HEIGHT: .098”
WEIGHT: 299 GRAMS
B17A1 P61:
ROD LENGTH: 5.208”
STROKE: 3.205”
COMPRESSION HEIGHTS: 1.181"
DOME HEIGHT: CAN’T FIND YET
WEIGHT: CAN’T FIND YET
B18A1 PR4:
ROD LENGTH: 5.394”
STROKE: 3.504”
BORE SIZE: 3.189“ (81MM)
DOME HEIGHT: -.055”
WEIGHT: 280 GRAMS
B18C1 P72
ROD LENGTH: 5.429”
STROKE: 3.433”
DOME HEIGHT: .000”
WEIGHT: 305 GRAMS
B18C5 P73-A0
ROD LENGTH: 5.429”
STROKE: 3.433”
DOME HEIGHT: .070”
WEIGHT: 310 GRAMS
B20B
ROD LENGTH: NA
STROKE: NA
BORE SIZE: 3.307” (84MM)
COMPRESSION HEIGHTS: 1.165”
DOME HEIGHT: -.035”
WEIGHT: 312 GRAMS
H22A
ROD LENGTH: 5.63”
STROKE: 3.571”
BORE SIZE: 3.425” (87MM)
COMPRESSION HEIGHTS:1.222"
DOME HEIGHT: NA
WEIGHT: NA
H23A1
ROD LENGTH: 5.571"
STROKE: 3.740"
BORE SIZE: 3.425" (87MM)
COMPRESSION HEIGHTS: 1.203"
DOME HEIGHT:NA
WEIGHT: NA
D15B1/ 2/ 7/ 8
ROD LENGTH: 5.275”
STROKE: 3.326”
BORE SIZE: 2.933” (74.5MM)
COMPRESSION HEIGHTS: 1.208”
DOME HEIGHT: .000”
WEIGHT:
D16Z6
ROD LENGTH: 5.393”
STROKE: 3.543”
BORE SIZE: 2.952” (75MM)
COMPRESSION HEIGHTS: 1.181”
DOME HEIGHT: -.118”
WEIGHT:NA
D15Z1
ROD LENGTH: 5.393”
STROKE: 3.326
COMPRESSION HEIGHTS: 1.092”
DOME HEIGHT: -.277”
WEIGHT:NA
D16Y7
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.130”
WEIGHT:NA
D16Y5
ROD LENGTH: 5.393”
STROKE: 3.543”
COMPRESSION HEIGHTS: 1.161”
DOME HEIGHT: -.106”
WEIGHT:NA
D16Y8
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.083”
WEIGHT:NA
D17A1
ROD LENGTH: 5.511”
STROKE: NA
COMPRESSION HEIGHTS: 1.062”
DOME HEIGHT: -.106”
WEIGHT:NA
D17A2
ROD LENGTH: 5.511”
STROKE: NA
DOME HEIGHT: -.104”
WEIGHT:NA
ROD TECH:
ROD/STROKE RATIO AND ROD LENGTH:
B16A: 1.74/ 134MM
B17A1: 1.62/131.87MM
B18A1: 1.54/ 137MM
B18B: 1.54/137MM
B18C1: 1.58/137.9MM
B18C5: 1.58/137.9MM
B20A3/53RD GEN LUDE) 1.50/142.75MM
B21A1: 1.492/141.7MM
B20B: 1.539/137MM
H22A: 1.577/143MM
H23A1: 1.49/141.5MM
F20C: 1.821/153MM
D17A1: /140MM
D17A2: /140MM
D16Y8: 1.52/137MM
D16Y7: 1.52/137MM
D16Z6: 1.52/137MM
D16A1: 1.52/137MM
D16A6: 1.52/137MM
D15B1: 1.59/134MM
D15B2: 1.59/134MM
D15B7: 1.59/134MM
D15B8: 1.59/134MM
ZC: 1.52/137MM
Old Dec 7, 2005 | 01:51 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">There is no difference between the two, they have the same stroke....I don't know if the ITR is factory balanced making it better for higher RPM....but other then that...?:</TD></TR></TABLE>
The weights were what the all motor guys were debating. IIRC they were trying to figure out if the which one was better the heavier or lighter crank.
Old Dec 7, 2005 | 01:57 PM
Muckman's Avatar
Moderator in Chief
Why would heavier ever be better? As long as its balanced I dont see the logic of heavier counter weights.
Old Dec 7, 2005 | 01:58 PM
RyanEJ8's Avatar
The best crank for boost is the kind you get from that shady looking guy on the corner of MLK and 22nd St.
Old Dec 7, 2005 | 02:07 PM
BlueShadow's Avatar
Default Re: which crank is better for boost? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Why would heavier ever be better? As long as its balanced I dont see the logic of heavier counter weights.</TD></TR></TABLE>
well I was just reading the discussion, not really participating. But from what I read a lighter crankshaft would rev faster. At least that's what the guys were debating in the all motor thread I was reading.
Old Dec 7, 2005 | 02:21 PM
_gurusan_'s Avatar
It's the same concept as a flywheel, a lighter crank will rev faster and put more transfer more and throttle response.....a heavier crank will rev slower but once it got up there it would have more momentum equaling more power.
Old Dec 7, 2005 | 02:36 PM
DC2 to AP2's Avatar
wow! alot of great info in there! i guess now i just need to figure out which one to use.
Old Dec 7, 2005 | 02:37 PM
DC2 to AP2's Avatar
for a LS crank... what rods and pistons do you use?
Old Dec 7, 2005 | 03:21 PM
_gurusan_'s Avatar
I would imagine LS length rods and any b-series pistons
Old Dec 7, 2005 | 07:10 PM
fullblown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">I would imagine LS length rods and any b-series pistons</TD></TR></TABLE>
Old Dec 7, 2005 | 08:51 PM
Muckman's Avatar
Moderator in Chief
I agree lighter is better. Thats why Id always pick a GSR over an ITR crank, same stroke, but lighter. I just dont get why Honda would make the ITR crank heavier. Is there an advantage?
Old Dec 7, 2005 | 09:02 PM
_gurusan_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">It's the same concept as a flywheel, a lighter crank will rev faster and put more transfer more and throttle response.....a heavier crank will rev slower but once it got up there it would have more momentum equaling more power.</TD></TR></TABLE>
i was just theorizing but this is what I posted above....it doesn't make sense really because the ITR seems like it would be optimized for throttle response and stuff.....
but at higher RPMs the momentum of the heavier crank might result in increased power output.
Old Dec 7, 2005 | 09:09 PM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imola-red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">for a LS crank... what rods and pistons do you use?</TD></TR></TABLE>
you will use LS rods , and the pistons will be for what head you use to keep the compression ratio right
MrXclusivE
Aug 7, 2009 11:13 AM
jksmith
Jun 28, 2008 11:39 AM
hondaeg8
Jun 27, 2005 10:22 AM
Integ03
21
Nov 2, 2003 07:35 PM
GokuSSJ4
Mar 5, 2002 01:40 PM
