throttle body on turbocharged car
When you have a turbocharged full modded car with an bigger intake manifold. Is it smart to buy also a bigger throttle body or doesn't that help much to increase horsepower?
Re: throttle body on turbocharged car (xtremecoupe)
I'm not sure about actually hp increases, but you need to size the throttle body based on the size of your IC piping.
Re: throttle body on turbocharged car (Chris22215)
more air you can get to the cylinders the more power you will make. but you dont need anything over kill a 70mm-74mm t/body some where on that area will do fine
in FI applications incresing the throttle body size will have minimal returns when compaird to a NA.. turbo mustang guys are running 8's on holley 650's
and thats a small carb
Re: (SSBPGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR »</TD></TR><TR><TD CLASS="quote">just dont get a TB with a larger opening than your intake manifold has and youll be fine. </TD></TR></TABLE>
you can go a little over. just get your intake manifold ported to help with the flow..
platinum.
platinum.
Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremecoupe »</TD></TR><TR><TD CLASS="quote">When you have a turbocharged full modded car with an bigger intake manifold. Is it smart to buy also a bigger throttle body or doesn't that help much to increase horsepower?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar »</TD></TR><TR><TD CLASS="quote">in FI applications incresing the throttle body size will have minimal returns when compaird to a NA.. turbo mustang guys are running 8's on holley 650's
and thats a small carb </TD></TR></TABLE>
OK here is another question: What about when you are daily driving out of boost? would a larger throttle body increase throttle response until you hit boost?
Re: (Importordomestic)
i used to run a bigger TB on my N/A setup along time agian, and i noticed better Throttle response. i dont see why it would be any different on a Turbo application
platinum.
platinum.
Re: (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">i used to run a bigger TB on my N/A setup along time agian, and i noticed better Throttle response. i dont see why it would be any different on a Turbo application
platinum.</TD></TR></TABLE>
Cool Beans
Cool Beans
