turbo problems
Old Dec 6, 2005 | 02:19 PM
98redDXturbo's Avatar
Default turbo problems
i have a d16y7 with a td04h turbo set up on it fmu ,injectors,plugs,retarded timingand i have two problems one my oil smells like gas and two when i hit 6 pounds of boost the car stutters and drops boost to 5 then it pulls again i have the missing link for the map sensor so i know its not that i would appreciate any help you can give this is the setup i have
vortech 10-1 FMU
240cc injectors
tdo4h turbo
6psi boost
missing link
dsm blow off valve
zex turbo plugs
timing retarded2 degrees
internally wastegated
fuel management wasnt the problem on the first motor i had a fuel leak and when i hit boost, mixture too lean melted #4 piston
Modified by 98redDXneedsAheart at 11:07 AM 12/10/2005
Old Dec 6, 2005 | 02:21 PM
crxnj's Avatar
Default Re: turbo problems (98redDXneedsAheart)
Your oil smelling like gas is because its probably running crazy rich--FMU,bigger injectors and retarded timing = pig rich
Old Dec 6, 2005 | 02:42 PM
platinum00's Avatar
Default Re: turbo problems (Mr.speaker)
you posted this in the civic forum as well.
you also mentioned that you had the same setup on your last motor the lasted a day and you blew the motor
ill post the same thing here
and you put the same fuel mangement on the 2nd motor.
learn from your mistakes and get rid of the FMU.
list a little more detail about your setup
what size turbo?
how much boost?
what size injectors?
what kind and size FMU?
platinum.
Old Dec 10, 2005 | 10:35 AM
Default Re: turbo problems (platinum00)
also still running the stock mid section would that have anything to do with it? 1 3/4id down pipe is 2 1/2 id
Old Dec 10, 2005 | 10:45 AM
Dartanian's Avatar
Default Re: turbo problems (98redDXturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98redDXturbo &raquo;</TD></TR><TR><TD CLASS="quote">also still running the stock mid section would that have anything to do with it? 1 3/4id down pipe is 2 1/2 id</TD></TR></TABLE>
No, your half-assed fuel management is the problem.
Get something tunable, some larger injectors, and some dyno tuning done and that will most likely fix your problem.
Old Dec 10, 2005 | 10:49 AM
Default Re: turbo problems (Das Schmoo)
so as far as tuning what would you reccomend safc, obd1 conversion w/hondata or similar? because i would like to stay obd2 because of emmisions its a daily drive ...would i still pass if i went obd1
Old Dec 10, 2005 | 10:53 AM
also my friend is running the same setup but doesnt have any problems...only difference is the turbo and the manifold he is running t3 with log mani mines tubular and tdo4h
Old Dec 10, 2005 | 09:59 PM
Dartanian's Avatar
Keep the OBD2 stuff around so that when emissions tests come around, you can put that on. I recommend a chipped ECU running your choice of engine management: Hondata, Crome, Uberdata, etc.
Luward
Apr 29, 2008 04:46 AM
foreverwefall
33
Nov 18, 2006 04:35 PM
98redDXturbo
Dec 10, 2005 10:43 AM
1990hondaHF
Aug 13, 2005 10:37 PM
Go Fast Civic
Dec 1, 2004 01:09 PM
