FASTEST SPOOL ?
Old Dec 13, 2005 | 11:15 AM
nekoabandoned's Avatar
Default FASTEST SPOOL ?
what turbo would have the fastest spool time if im going for 13psi?
Old Dec 13, 2005 | 11:24 AM
97CWITR's Avatar
Default Re: FASTEST SPOOL ? (nekoabandoned)
SEARCH!
gt14 would probably spool quick?
...and why 13psi?
Old Dec 13, 2005 | 11:25 AM
jc@douglas's Avatar
Default Re: FASTEST SPOOL ? (96BLkGSR)
any certain power goals in mind?
mrx's Avatar
mrx
i think it depends mainly on the engine you have... a b16 will make another spool up time then a b18...
by the way... small turbo=fast spool up
big turbo = late spool up...
it's up to find a middle way because a small turbo with less spool is useless if he has no topend...
read something about compressor maps/turbine housings and you will see.... there is no general answer to this question.
Best regards
Malte.
Old Dec 13, 2005 | 11:44 AM
Default Re: FASTEST SPOOL ? (mrx)
220 hp is my goal, and youll see my setup if you read at the bottom of my posts i just want a daily driver that can spank ricers
Old Dec 13, 2005 | 11:52 AM
jc@douglas's Avatar
94 del sol si
t3/t4 turbo
everything aem makes
d16z6
broken boost gauge
lifes fun if your neck hurts
what does your t3/t4 spool at and how much power are you making now? if you want something to spool hella quick use a peanut shooter gt28 or something, but low end power breaks tires loose and that doesn't always win a short race
Old Dec 13, 2005 | 11:55 AM
Default Re: FASTEST SPOOL ? (jc@douglas)
spools at like 4k, im going to keep the z6 tranny with the short gears so i just wanted to feel a turbo that can spool at 2k. prob. need a new turbo anyways
Old Dec 13, 2005 | 11:56 AM
how much of a difference does charge pipe make on spool times?(dont flame!)
Old Dec 13, 2005 | 12:19 PM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned &raquo;</TD></TR><TR><TD CLASS="quote"> 220 hp is my goal, and youll see my setup if you read at the bottom of my posts i just want a daily driver that can spank ricers </TD></TR></TABLE>
You sound like a ricer to me... Do some research, a 42/48 T3 is the smallest turbo I would go on a D16, otherwise the car will fall on its face above 6K. Read up newb.
Old Dec 13, 2005 | 12:25 PM
wisjdmhonda's Avatar
Default Re: FASTEST SPOOL ? (nonvtecD)
what about the gt28rs (disco potato) I hear that spools pretty quick.
Old Dec 13, 2005 | 03:28 PM
urbansi's Avatar
Default Re: FASTEST SPOOL ? (rota92)
whoa whoa whoa, you forgot the bypass valve yo
Old Dec 14, 2005 | 02:06 PM
Default Re: FASTEST SPOOL ? (urbansi)
lol all but the crap i dont need
Old Dec 15, 2005 | 07:17 PM
thanks for not answer my questions , maybe someone that has some sort of knowladge in the area of the questions i asked could put up a post ....bump for someone to help with the charge pipe question
Old Dec 15, 2005 | 07:34 PM
turbotime's Avatar
charge pipes wont make any diff dude. its just pressure being built in a system. Most applications go from small at the turbo to large at the tb, i dont know the logic around it.
trust me worrying about your charge pipe is the last thing you needs to worry about, a 2.5"-3" main charge pipe is fine, for your ic pipes etc you can either go one size feom the turbo all the way to the tb or slowly increase the size.
I have DRAG pipes so they start at like 1.25" or something at the tubo and end at like 2.75" -3" at the throttle boddy, increasing slowly thourghout the piping. Its weird and i thought it was way too small at first but its great.
Anyway- charge pipes are your last concern. Think about what turbo u want, wastegate, EMS, fuel setup, injectors, CATCH CAN (much more important than most realize), manifold, etc.
In my mind these allll come before any thought of charge pipes.
I use the drag t3/t4 not sure which one exactly- i know its one of the smaller ones. Its ******* awesome, it starts building boost around 3k and i have full boost by like 4.5k and it pulls HARD all the way to 8.8k.
just my .02
Old Dec 15, 2005 | 08:28 PM
Default Re: (turbotime)
im going to just stick with my t3/t4 for now,i was wondering if i was having bad lag because i was using exhuast piping(not mandrel bend) in and out a ford probe intercooler.there all very sharp bends,and to top it off im running 2'' all the way through the system. so im picking up some charge pipe 2.5" tomarrow and a front mount,will this fix some of the lag?
Old Dec 15, 2005 | 08:37 PM
turbotime's Avatar
Default Re: (nekoabandoned)
what size downpipe and exhaust are you running?
Old Dec 15, 2005 | 08:38 PM
2.5 all the way back
Old Dec 15, 2005 | 09:54 PM
.....bump
Old Dec 15, 2005 | 10:03 PM
crxnj's Avatar
t3-super 60 turbo seems to be a good match with the d16z6..
93first1
Apr 5, 2006 05:12 AM
DC2 BoZz
Sep 25, 2004 07:44 PM
riceburnah
Jul 14, 2004 08:02 PM
BLKCRX
Apr 23, 2003 01:13 AM
bearboy80
Apr 4, 2003 04:39 PM
