sea foam on a turbo car?
Re: (DJ Gurgla GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ Gurgla GSR »</TD></TR><TR><TD CLASS="quote">the can clearly says not to use seafoam on turbocharged or rotary engines</TD></TR></TABLE>
I thought the can clearly says its safe for turbo cars? Maybe Im thinking O2 sensors...
Re: (nekoabandoned)
There was a guy that Seafoamed his turbo car a few months ago and he didn't have any problems with it.
I haven't seafoamed my car through the crank case, but I have put it through my gas with zero troubles.
I'll have to reread my can. I never saw that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">I thought the can clearly says its safe for turbo cars? Maybe Im thinking O2 sensors...</TD></TR></TABLE>
I do remember it saying that on the can.
Re: (Everyones Hero)
I did it. It's fine. I took out the o2 sensor and I have no cat. Those are the only things that can get fouled. Nothing else will happen, just change your oil afterwards.
Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">I did it. It's fine. I took out the o2 sensor and I have no cat. Those are the only things that can get fouled. Nothing else will happen, just change your oil afterwards.</TD></TR></TABLE>
And plugs, right?
And plugs, right?
Re: (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">lol i guess ill try it (booom!)mit happen,can some1 give me some pointers on using it ?</TD></TR></TABLE>
Open the oil cap, pour in 1/3 can, replace oil cap.
Get into car. Start it up.
Go for a joy ride.
Park the car and get out.
Drain the oil, replace the plugs, add new oil.
Go for a joy ride.
Location: The Village Hidden in the Leaves: Seattle, WA
replace oil cap?
i thought you pour 1/3 into the gas tank
pour 1/3 into the motor through the oil cap
and pour 1/3 into the brake booster vac?
Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 »</TD></TR><TR><TD CLASS="quote">replace oil cap?
and pour 1/3 into the brake booster vac?</TD></TR></TABLE>
There is no set way that you must use seafoam. It depends on what you are trying to accomplish. For dirty old engines, I usually do the 1/3 split between the crankcase, vac source, and fuel tank. In this case, I would prolly do 1/2 in the tank and 1/2 in the crankcase.
RACEPAK
01-22-2008 05:50 PM
h22_crx
03-13-2006 07:32 PM
