Anyone running a 3" downpipe on a Greddy kit?
I am trying to piece together a new exhaust for my Greddy setup and I am wondering if 3" is possible from the elbow back. It seems like the clearance from the oil line to the pipe is really small right now, so I wanted to see if anyone was running it and if they had clearance issues.
I also was wondering if 3" would be overpiping such a small turbo setup. Should I stick with a 2.5" downpipe and 3" exhaust instead?
This is for an Integra, BTW.
Re: Anyone running a 3" downpipe on a Greddy kit? (boostincoupe)
a 3in dp will gain you power reguardless. i would stick with the 2.5 DP and 3 inch exhaust though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">boooooooooost spikkkkeeeeeeeee </TD></TR></TABLE>
how so?
how so?
Re: Anyone running a 3" downpipe on a Greddy kit? (richeybrooks)
OK, I'll probably just run a 2.5" and not worry about clearance issues. The bottleneck still exists at the elbow, though.
Re: Anyone running a 3" downpipe on a Greddy kit? (Das Schmoo)
my friend locally makes a 3in DP for the greddy kit, bolts up to the elbow and on the 2 cars he made it for, he didn't have any spiking issue, just went 3in off the elbow, under the oil pan and then into 3in exhaust or open dump. the biggest problem he had was the stock return line will melt if next to the downpipe, so had to redo the line in Stainless steal and wrapped the DP with heater wrap, no issues thus far and if imagineable, the car spools faster.
2.5 seems best for the greddy set up..
that is what i was running on mine and i noticed a bit of a power increase over the tiny 2 inch DP
Re: Anyone running a 3" downpipe on a Greddy kit? (hybrid93SIvic)
so the stock dp is 2 inches? cause i still have the stock one and was thinking about going 2.5 or 3 what do you guys think?
Re: Anyone running a 3" downpipe on a Greddy kit? (seen4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever »</TD></TR><TR><TD CLASS="quote">my friend locally makes a 3in DP for the greddy kit, bolts up to the elbow and on the 2 cars he made it for, he didn't have any spiking issue, just went 3in off the elbow, under the oil pan and then into 3in exhaust or open dump. the biggest problem he had was the stock return line will melt if next to the downpipe, so had to redo the line in Stainless steal and wrapped the DP with heater wrap, no issues thus far and if imagineable, the car spools faster.</TD></TR></TABLE>
Yeah, I redid the oil return line because it was leaking and the heat wrap **** was a joke. I am still worried about it rubbing against the downpipe, so I will probably just opt for a 2.5" DP instead.
a 2.5 would flow nicely for a greddy kit. and also it allows more room, just flair to 3'' under the oilpan. thats what i would do.
Let us know how it turns out when your done
Just do what i did, buy a 3inch v-band adapter from ATP turbo (replaces elbow) then buy some bends and fab up the whole thing. while you are in there port the wastgate and take care of the possible boost spike. The turbo will spool so much faster with that elbow replaced, and the elbow is what robs you from a lot of power. Just be prepared to lose the A/C.
Re: Anyone running a 3" downpipe on a Greddy kit? (urbansi)
i dont have ac i think im going to price a 2.5inch on payday! its kind of hard to imagen fast spool on a greddy kit
Re: Anyone running a 3" downpipe on a Greddy kit? (lshatch1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch1.8 »</TD></TR><TR><TD CLASS="quote">i dont have ac its kind of hard to imagen fast spool on a greddy kit </TD></TR></TABLE>
