smoke from valve cover breather hole..
my car was runnin fine the other day.. but my fan shroud ate a hole through one of my vacum lines then i boosted 14 by accident a couple times.. i fixed it back to five.. but now my car dosent start correctly.. and smoke comes out of my valve cover breather hole.. wat is wrong.. is it normal.. and when i drive smoke comes into my car but dosent smell like anything.. i checked to see if n e thing was burning nothing.. looked in my valve cover for water... none..
Re: smoke from valve cover breather hole.. (Ls-Turbo)
Sounds like you have excessive blow-by.
Maybe you burned your piston rings!
This happened to me with my D16Z6 turbo!
Did you do a compression test?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls-Turbo »</TD></TR><TR><TD CLASS="quote">my car was runnin fine the other day.. but my fan shroud ate a hole through one of my vacum lines then i boosted 14 by accident a couple times.. i fixed it back to five.. but now my car dosent start correctly.. and smoke comes out of my valve cover breather hole.. wat is wrong.. is it normal.. and when i drive smoke comes into my car but dosent smell like anything.. i checked to see if n e thing was burning nothing.. looked in my valve cover for water... none.. </TD></TR></TABLE>
don't run the car until you do a compression test.. probably cyl #3 as in most cases]
smoke at high rpm is acceptable, why i don't run breather filter - it gets clogged up and restricts ventilation. smoke at idle or low rpm is a different story and a sign of worn out seals or worse.
fried pistion rings or cracked pistons, or broken ring lands. All cases are bad and not a easy fix. Happened on two sets of LS pistons i had, now i have a built motor so i dont have to worry.
Re: smoke from valve cover breather hole.. (KillerBee18)
is it bad to drive on the motor..? wats the worst that could happen from bad rings..?
i would not recommend driving because u could make it worse because u can damage the walls of the sleeves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerBee18 »</TD></TR><TR><TD CLASS="quote">i would not recommend driving because u could make it worse because u can damage the walls of the sleeves.</TD></TR></TABLE>
drive and beat the **** out of it, most likely your going have to bore and hone.
Re: smoke from valve cover breather hole.. (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">
drive and beat the **** out of it, most likely your going have to bore and hone. </TD></TR></TABLE>[QUOTE=Boosted Chemist]
lol ill super beat it up when i go pick up my b20.. lol.. iamma get my bottom end cryogened..
oh yea piston 2 was at 60// others were 125.. not too bad for ls lol
Re: smoke from valve cover breather hole.. (88_DX)
u have to remeber this is an ls motor which is already low comp..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88_DX »</TD></TR><TR><TD CLASS="quote">new pistons. If the other three are at 125 sounds like you broke all 4 good work </TD></TR></TABLE>
Re: smoke from valve cover breather hole.. (PRELUDE-GT35R)
guys i was wondering, i got about 200 miles on my rebuilt motor/turbo. I get smoke slight smoke out of my breather, but it only seems to come out when the car is off after a drive. ?
Re: smoke from valve cover breather hole.. (kuja)
dont trip new motor is on the way... ceramic coated headers.. cryogened complete block.. block gaurd, bore, hone.. should be good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls-Turbo »</TD></TR><TR><TD CLASS="quote">dont trip new motor is on the way... ceramic coated headers.. cryogened complete block.. block gaurd, bore, hone.. should be good</TD></TR></TABLE>
Yep nothing lke headers and a turbo.
Re: smoke from valve cover breather hole.. (SOHCD16y8)
hehe i want a header for my turbo where can i get one?
i would get AAA then turn the turbo back to 14psi... and accidently
run up a couple of times....
fun stuff there..
then i would call a junk yard for another engine.. and before you put it in,
new pistons, oversizes bores, big connecting rods.. and at least have the head rebuilt so the valves dont leak... then i would run 14 psi all the time!!
even more fun!!
5 o 14 on accident... tee hee - tee hee
fun stuff there..
even more fun!!
Re: smoke from valve cover breather hole.. (Trailz-EX)
lol edit.. i meant ceramic coated pistons.. and ceramic coat my turbo manifold..
Gummiej
07-18-2006 12:09 AM
Diego Boost
01-06-2003 01:28 PM
