Ignitor Bypass with msd
Old Dec 7, 2005 | 04:07 PM
lucidvtec's Avatar
Default Ignitor Bypass with msd--UPDATE
This is continued from another topic https://honda-tech.com/zerothread?id=1453299
This might be helpful for some
EDIT-- i used the J&S diagram for the bypass
Well I got the ignitor bypass finished…..it didn’t take to long and I spent about 35 bux just in parts
The project box
preppin the box…..i added some spacers to the box to bring the board up ..also added a plastic grommet…and some mounting tabs as well
here is the pcb with the main wires attached
the board with a few components
the underside of the pcb
board all done minus the ztx857 it was installed along the side of the box…with thermal paste…i used the box as a heatsink
finished product
I will be installing this tomorrow in my GSR-T….with a msd 6a, blaster SS coil, and msd modified cap..
Modified by lucidvtec at 3:13 PM 12/10/2005
Old Dec 7, 2005 | 04:47 PM
Syner-G-Racing LLC's Avatar
Default Re: Ignitor Bypass with msd (lucidvtec)
looks clean man, make sure you post of the final install. If you mount it in the engine bay make sure you seal that box up with some silicone
Old Dec 8, 2005 | 10:30 AM
lucidvtec's Avatar
there is no room in my motor bay.....i'm gonna have to move some stuff around...i will be done with the install tomarrow night...i'll post with the results soon
Old Dec 8, 2005 | 11:38 AM
rudebwoy's Avatar
do you have a parts list for this bypass setup? I fried 5 igniters and one distributor in one month using the msd 6a and blaster 2 coil
Old Dec 8, 2005 | 12:07 PM
*Boostwerks*'s Avatar
Looks great... PM sent...
Old Dec 8, 2005 | 01:27 PM
Default Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">do you have a parts list for this bypass setup? I fried 5 igniters and one distributor in one month using the msd 6a and blaster 2 coil</TD></TR></TABLE>
you've got other issues if you f#$@ed up 5 ignitors in a month...send the 6a box back.
Old Dec 8, 2005 | 01:30 PM
DRAGLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">do you have a parts list for this bypass setup? </TD></TR></TABLE>
So?
Old Dec 9, 2005 | 01:09 AM
lucidvtec's Avatar
Default Re: (DRAGLS)
here is the link for the diagram
http://www.pgmfi.org/twiki/bin...ement
parts list::
2 - 1k 1/4watt Resistor
1 - 4.7k 1/4watt Resistor
1- 2n2222 npn transistor
1 - ztx857 high power npn transistor
1 - blank circuit board
1 - project box...i used metal so i would not to use a heatsink
1 - thermal paste
u can get all the parts from http://www.digikey.com
Old Dec 9, 2005 | 02:11 AM
DaveF's Avatar
Default Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec &raquo;</TD></TR><TR><TD CLASS="quote">here is the link for the diagram
parts list::
1 - thermal paste
did you install the box yet?
Old Dec 9, 2005 | 11:56 AM
tgreaves's Avatar
So basically you built a fast acting solid state relay right?
Old Dec 10, 2005 | 01:12 PM
lucidvtec's Avatar
ok....i installed everything
it started up the first time and idled perfect
for about 3 minutes
then died...
no fuses were blown
perfect install...i will post pix soon
car still wont run...i took out the bypass box and the 6a wired it back to the external coil
still nothing
is it possible my ECU "p72" got fawked up
no check engine lights and the hondata lights up ok
just no spark
i'm gonna replace the whole dizzy asap...hopefully i can drive my car
Old Dec 10, 2005 | 04:19 PM
lucidvtec's Avatar
bump....help me out...........how could i tell if my ecu is good....i think the ignition might have been screwed up
Old Dec 11, 2005 | 02:48 AM
lucidvtec's Avatar
ttt
Old Dec 11, 2005 | 07:40 AM
2SLO's Avatar
rut roh, good luck man!
Old Dec 11, 2005 | 12:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec &raquo;</TD></TR><TR><TD CLASS="quote">bump....help me out...........how could i tell if my ecu is good....i think the ignition might have been screwed up</TD></TR></TABLE>
Oh ****, thats not good.
I thought that a code 1 is a faulty ECU.
Old Dec 11, 2005 | 12:56 PM
lucidvtec's Avatar
car seems fine....no spark....no check engine lights....light is soild on the my hondata....car turns over fine...just won't start
Old Dec 11, 2005 | 01:01 PM
lucidvtec's Avatar
i thought i didn't need this anymore
bypass box mounted on firewall
finished...msd amp where the main wiring harness should go....coil is by the radiator can....bypass is on the firewall
i wish it still worked....the msd box was used..but from a good source..it could have went bad...or maybe my ecu ign. output..or tach input...who knows......hopefully when i replace the dizzy with a completly stock one it will start right up..if not i will know it's the ecu
newbie question...i don't know how to use a timing light or adjust my dizzy...i'm gonna swap it my self since there is only 3 bolts...try and line it up as close as the other....i know the rotor has to be in phase.....any suggestions????
Modified by lucidvtec at 3:13 PM 12/11/2005
Old Dec 11, 2005 | 01:19 PM
B18C1CYA's Avatar
The dizzy key is off set so it will only drop in one way , also pull the cover off your ecu and see if any thing is fried, sounds like some thing took a **** after it had load for a while , let us know how you make out
Old Dec 11, 2005 | 03:24 PM
lucidvtec's Avatar
Default Re: (B18C1CYA)
i pulled the covers off my ECU everything looks fine...anyway to test it
Old Dec 11, 2005 | 03:47 PM
2SLO's Avatar
leave the stock igniter pluged in and try it
Old Dec 11, 2005 | 04:31 PM
EE_Chris's Avatar
You can also manually test the MSD to eliminate it as a variable.
Do you have a multimeter? Use it to see if the Yel/Grn ICM trigger wire from the ECU is pulsing while cranking the car. I wouldn't use a test light though. The reason you ever made this ignitor bypass was because the stock ECU doesn't really have enough juice to trigger the MSD. So if you try and use a test light, it acts as just about as big a load as the MSD does and may or may not work to show activity on the trigger wire.
Old Dec 11, 2005 | 04:50 PM
Blackack26's Avatar
Default Re: (EE_Chris)
Old Dec 11, 2005 | 04:55 PM
onePOINTsix's Avatar
Default Re: (Blackack26)
thats for tabacco use only i bet my guess is that something in the curicut board took a dump
Modified by onePOINTsix at 9:19 PM 12/11/2005
Old Dec 11, 2005 | 10:03 PM
lucidvtec's Avatar
lol...bump
Old Dec 12, 2005 | 12:05 AM
BoOsTiN Dc2's Avatar
whats the purpose for this?
