EFI / Electrical Problem(s)
Old Dec 10, 2005 | 09:24 PM
alpha's Avatar
Default EFI / Electrical Problem(s)
I dont know where to begin. I know I am leaving a lot out. I'm very tired
The car is a DA Integra with a freshly built B18c1 bottom end with a B16a top end. AEM EMS 30-1000 & 30-1040 engine management system, Precision 1,000cc fuel injectors, GM 3 bar map sensor, etc. The car ran fine with a built B16a and the same AEM EMS 30-1000 box. Shattered an oil pump gear and that was the end of that motor. I have already put 50 light miles on the motor by using the TPS voltage for the engine load. Here is the problem. I'm getting 1.54v from the GM 3 bar map sensor. It's reading about a pound of boost with the ignition on, at startup and if the car tries to idle. I have tried just about everything short of replacing the entire harness. Mase has ever sent me a calibration to rule that out I have one more idea I am going to try after my 1:20am dinner
Old Dec 10, 2005 | 09:30 PM
.dave's Avatar
i HAS questions ?
Default Re: EFI / Electrical Problem(s) (0x64)
Did you try using a different MAP sensor?
Old Dec 10, 2005 | 09:49 PM
alpha's Avatar
Default Re: EFI / Electrical Problem(s) (daveG)
See. I left quite a bit out of the post I have tried four map sensors. One of those being an OEM Honda MAP sensor.
Old Dec 10, 2005 | 09:50 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">See. I left quite a bit out of the post I have tried four map sensors. One of those being an OEM Honda MAP sensor.</TD></TR></TABLE>
Ahah I figured. Just making sure though. So all the sensors had the same voltage at idle? I'd check the continuity from the sensor connector to the ECU plug and see whats up.
EGmmBAH
Feb 26, 2007 03:14 AM
JTCdudeman
Dec 1, 2005 07:48 AM
int3gra
Jul 4, 2003 11:49 AM
R THIS
Jun 12, 2003 04:01 PM
Brian_92GSR
Nov 3, 2002 05:28 PM
