The project I’ve been work’n since Sep (56k get a book)
UPDATE PAGE 4
new pics added page 2
I would like to say thanks the elits3.com from letting upload a ton of pics.
The car is a 90 si
the plan, take a 90si
and add this gt2871r
HKS manifold
old set up
starting the mock up, johnnyracer black FMIC
trimed the fat, and welded it back together
hung
checking fitment
mocking up the charge pipes
BOV
insurance
man, ef have sooooo much room! not.
out she goes
Some times we need a kick in the *** to get started, this was my kick in the ***
This caused quite a stir a couple month ago lol
this is my homeboy Root, he is crazy dude!
new head gasket in. adjusting valves. yes thats my first attempt at a down pipe, and yes I’m ashamed of it.
oil return time
450 blue tops in and a new intake gasket
Dean, thanks for the engine prop
tuner toys oil T
i love that tq wrench
I decided to keep the stock flywheel, and that’s a CM FX300 Kevlar disc. The guys a Clutch Masters provide great customer service
“tobrocoup” (SP) came up with an idea to tap the bolt in the front of the block to feed the turbo coolant line. So I sole it. Seems to work pretty good. I taped the thermostat housing for a return line. All the tapping was done on an old block and then cleaned before installed. DO NOT TAP STUFF ON YOUR BLOCK!
I used a golden eagle vacuum manifold, I tack welded the nuts to the back of the fire wall to make taking it on and off easier.
It makes my brain hurt just to look at it. keep you dash in a cool dry place!
back in!
Sexy, aluminum
One step forward, two steps back., was the theme of this build!
Make a new down pipe, its ok because the first one was a travesty! I had to do something with the radiator as well it was supposed to fit crx’s but was too tall. I fab a lower mount and got a sweet 1400cfm fan for it. Ran the lines.
All back together, and tragedy struck! “cut it off, cut it off….OIL”. a few months back in a late night cram we put the head gasket on backwards. ****!!!!!!!. Well the next morning we hit it. Took the head off and replaced the head gasket. It only took us a few hours to get it all back together. I burned a base map on crome pro. Primed it and let it run through a heat cycle. Small problems, fan wired backwards, and a few really small oil leaks or it might just be left over oil from the great head gasket incident.
Now I just gotta tune it. I have crome pro and a plx m300, I need some help getting it all hooked up, like a how too.i posted on pgmfi.org but no response yet, here is a link to Pgmfi if you would like to look at the base map or give me a hand getting startedhttp://forum.pgmfi.org/viewtopic.php?p=55688#55688. And the same goes for tuners around where I live. So any suggestions or help would be greatly appreciated.
Feel free to ask any questions that I might be able to help with. Thanks!
Modified by abnaasefmb at 12:28 AM 12/12/2005
Modified by abnaasefmb at 12:41 AM 12/12/2005
Modified by abnaasefmb at 4:13 AM 12/21/2005
Modified by abnaasefmb at 4:16 AM 12/21/2005
Modified by abnaasefmb at 4:55 AM 12/10/2006
The car is a 90 si
HKS manifold
old set up
hung
checking fitment
BOV
insurance
out she goes
oil return time
tuner toys oil T
back in!
Sexy, aluminum
Sweet work man. I like the fab work for the rad mount :D I've seen a few ppl do the water return line into the front of the block like you aw well. Seems like a good idea to elimiate running 2 liens to the back of the engine. GOod job man
Re: (Syner-G-Racing)
thanks syner-g! i would love some help about now. i'm soo tierd of reading. its all just getting jumbled up in my head.
Re: The project I’ve been work’n since Sep (abnaasefmb)
OIL DUMBASS......lol that got me laughin, its the stupid **** that gets me to. Damn nice lookin project
Re: The project I’ve been work’n since Sep (SomeDude56)
Mikey,
Again brother fugging sweet. Those engine props are for sale. Just to let everyone know Mike is an old school VW fan who saw the light and converted to Hondas. He has only been tinkering with them for about 2 years.
Damn you took alot of pictures.....looks good!!!!!!! I wanna take up another project once i find a garage to keep my cars in.
Re: (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">thanks syner-g! i would love some help about now. i'm soo tierd of reading. its all just getting jumbled up in my head. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
GODDAM that exhast manifold is probably the cleanest thing on there, that thing's sick! Where'd you get that thing?! Heh, glad to see it'd being used. If I had kept my hatchie, it'd probably never had been removed from the plastic.
Buildup looks great, really like the red & painted mouldings. I'm guessing that's the big Greddy Type-R bov. I like how the charge pipe is routed off the turbo, I was planning the same thing for mine. Just have to say though, it'd look better if it was a 4dr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">“tobrocoup” (SP) came up with an idea to tap the bolt in the front of the block to feed the turbo coolant line. So I sole it. Seems to work pretty good. </TD></TR></TABLE>
You mean me??? Yeah I had that idea copyrighted so you will hear from my lawyers soon...J/K. It works great for me too, I used stainless hose and tapped it at the front water neck though. You should wrap(or even double-wrap) the DP, it comes pretty close to the plastic fan, mine melted a little once. Looks great, and everyone has a few problems when they first start it up, or a shitload in my case...
Re: The project I’ve been work’n since Sep (stockredej1)
I dont get why so many people do the ghetto radiator sideways lean thing. Put the fan on the front, and bring the bottom of it more forward.
Like this...
Just weld some mounts on the radiator support in front of the traction bar. It will look much better His car is N/A but u can see how much room it gives you.
I hope Juncr-x doesnt mind
Like this...
Re: The project I’ve been work’n since Sep (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">
GODDAM that exhast manifold is probably the cleanest thing on there, that thing's sick! Where'd you get that thing? </TD></TR></TABLE>
some dude named HIProfile.......the most avatar changing **** in the forum
Re: The project I’ve been work’n since Sep (TurboCoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop »</TD></TR><TR><TD CLASS="quote">
You mean me??? Yeah I had that idea copyrighted so you will hear from my lawyers soon</TD></TR></TABLE>
K.....low c en toe, yo no habla englais mucho bien!
