Having a problem with my Hondata s300
Old Dec 6, 2005 | 05:15 PM
Dancing is Forbidden's Avatar
Default Having a problem with my Hondata s300
Ok. So I put the hondata in, turn the key to the ON position and the laptop recognizes the ecu. I uploaded a map and started the car up this afternoon. Car ran like crap, Solid CEL (on the dash), no sensor information and no MAP tracing. I called my dealer who was stumped. Now I am wondering what is wrong. When I turn the car on and off the software recognizes the hardware change. And I can upload and download maps when the car is not running, but no real-time updates. UGH UGH UGH. Anyone, PLEASE HELP.
setup:
JDM b16a
89 CRX Si
Rywire harness
repinned dist.
o2 sensor hooked up.
Checked my wiring with a stock LS ecu and everything is fine, No CEL, idles fine, runs decent for an LS ecu. HELP!!!!
Old Dec 6, 2005 | 05:35 PM
Jaker's Avatar
Default Re: Having a problem with my Hondata s300 (ih8jdm)
Is your alternator working? I've noticed recently with the colder winter weather, that occasionally the battery gets low enough in the voltage department, that the S300 will drop out when starting the engine, and give a dead ECU type of symptom. Check your battery voltage when the engine is cranking/running with the S300 hooked up.
Old Dec 6, 2005 | 05:37 PM
Default Re: Having a problem with my Hondata s300 (Jaker)
yeah, my alternotr works fine. Also I am in charleston, sc where it was in the 60s today I think
Old Dec 6, 2005 | 06:39 PM
Marlon88's Avatar
Who did the installation ? Check if all the conections are Ok inside the ECU board , inspect all the soldering .
Old Dec 6, 2005 | 06:59 PM
D@nnY's Avatar
if you have a solid CEL its a probelm with the solder job or ecu.... make sure you have the up to date software since hondata fucked everyone in the *** that got it when it came out and relased an unfinished piece of crap product....
Old Dec 6, 2005 | 07:00 PM
Default Re: (D@nnY)
ok will do that since Ive had this unit for almost two months now.
Old Dec 6, 2005 | 07:01 PM
D@nnY's Avatar
Default Re: (ih8jdm)
they released it with software that doesnt work right with gm 3bar map sensors or large injectors...
Id like to give hondata a big expletive you
Old Dec 6, 2005 | 07:10 PM
Default Re: (D@nnY)
is the 1.1.1 the latest version?
Old Dec 7, 2005 | 05:32 AM
Old Dec 7, 2005 | 05:35 AM
D@nnY's Avatar
yes it is....you most likely will ahve to have it resoldered ..who installed it?
Old Dec 7, 2005 | 07:05 AM
done's Avatar
make sure your ecu is soldered correctly. and download the latest software. SManager 1.1.1
Old Dec 7, 2005 | 08:49 AM
locash's Avatar
Who is your dealer, and who did the ecu work?
You know how to get ahold of me if you need any help..
cleanazcoupe
Engine Management and Tuning
Jul 1, 2009 10:55 AM
TokuiAutowerks
Dec 13, 2004 07:29 PM
B18C1CYA
Apr 17, 2004 09:00 PM
VTgringo
Aug 19, 2003 05:01 AM
hybrid901
Jun 16, 2003 05:13 AM
