which turbo do you guys suggest???
i got a gsr, sleeved, 9:1 arias pistons, eagle rods, cometic head gasket, stock valvetrain(for now), 70mm throttle body, custom intake manifold, port and polish, stock gsr cams. 880cc injectors. i'm looking to be making 400whp+ which turbo do u guys think is best for my setup? and not crazy expensive. thanx
Re: which turbo do you guys suggest??? (high boosted rex)
http://www.importparts.com/sho...age=4
I usualy use this list to check maximum turbo output. of the precision turbo's they are fairly inexpensive. Choose your maximum hp or something you'd want to work with. I went with the SC61 *680hp*. Havn't achieved 680 yet. Im thinking of going with a smaller one thou for better efficiency / spool up.
Captain
Captain
Re: which turbo do you guys suggest??? (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD »</TD></TR><TR><TD CLASS="quote">Garrett GT3040R </TD></TR></TABLE>
or the GT30R.... The GT3040R will flow well over 500+ so im it might be a little much if all you're looking for is 400whp.
Re: which turbo do you guys suggest??? (CETVTOGEM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CETVTOGEM »</TD></TR><TR><TD CLASS="quote">i loke the PT61 from prescision, made 430whp@10psi on my friends stock block gsr pump gas</TD></TR></TABLE>
um
mysteriously ur friend made over 100 whp MORE than any other stock pump gas motor ive seen... for 10 psi that is
i call BS
um
i call BS
Re: which turbo do you guys suggest??? (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">
um
i call BS</TD></TR></TABLE>
um
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by high boosted rex »</TD></TR><TR><TD CLASS="quote">with the pt-61, how will my spool time be? lots of lag?</TD></TR></TABLE>
You can modify your spool time by changing the exhaust housing on the charger. If I were you I would seriously look into a Prescision Charger. If 400 whp is what you are looking for then I would consider the GT3271 w/25/8" inlet and 13/4" Outlet. I can sell you this charger for 599.99 plus shipping.
Give me a call @ 1-800-826-9843 or just click on my sig. and ask for Billy or Terry.
Must have had like 40 deg total timing in the map.
jk11blueboi
05-12-2007 08:28 PM
turboex
04-03-2003 06:39 PM
