Borg Warner and Porsche develop NEW Variable Vane Turbo!
Old Nov 29, 2005 | 05:38 AM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Default Borg Warner and Porsche develop NEW Variable Vane Turbo!
For the new 997 Turbo of course. You guys MAY or may not remember the Aerodyne turbo's that got discontinued a few years back for cooling and reliability issues.
For those completely clueless so far, the VVT's change surface area of the turbine wheel to effectively give you a zero lag application. This story reads kind of funny to me because it sounds like both sides with be variable, which will mean no lag and the potential for GOBS of boost tuneable on the fly.
Anywho, onto the story:
http://www.autoblog.com/entry/1234000257069829/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoblog.com &raquo;</TD></TR><TR><TD CLASS="quote">
November 16 of this year marked the day a century ago that Dr. Alfred Buchi received the first patent for an exhaust gas turbocharger. Porsche will be celebrating the turbo’s 100-year anniversary a little late when it introduces the next 911 Turbo sometime next year with Variable Turbine Geometry. This technology allows the angle of the compressor’s turbine blades to continually adjust. While some diesel engines have enjoyed this technology since the Nineties, the higher exhaust gas temperatures created by gasoline engines necessitated the creation of new heat-resistant materials to handle the hotness. Porsche and Borg Warner Turbo Systems were able to overcome the heat issue and have developed a VTG turbo system that will be incorporated into the next 911 Turbo. The VTG turbo will allow Porsche’s flat-six to mimic a twin-turbo setup with a much broader torque curve and more flexible powerband than a standard single turbo could provide on its own. Power ratings for the new VTG turbo engine haven’t been released and probably won’t be until the new 911 Turbo surfaces sometime next year.
Old Nov 29, 2005 | 05:49 AM
Boostage's Avatar
I have been following this for 4 years now. along with BMW's variable ratio transmission. this is an important breakthrough in the turbo community. although I cant help but wonder if it wont see the light of day in regards to the aftermarket because of cost. then again people buy $4k HKS t51R's. good find casey.
Old Nov 29, 2005 | 05:53 AM
Boostage's Avatar
Default Re: (Boostage)
Porsche didnt patent this right?
Old Nov 29, 2005 | 06:02 AM
mike1114's Avatar
Both sides would have to be variable. EDiT....IT isn't, just improved on the old design.
They already have the VNT turbos on the 89 daytona or whatever it was called. It was only variable on the turbine side. It was only a t25 capable of 250-280whp.
This one should be a variable geometry turbo where both sides have movable vanes.
Man I love these turbo's, there is so much innovation coming out now on turbo dynamics, its cool!!
El Chico
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">Porsche didnt patent this right?</TD></TR></TABLE>
I'm sure they will share the patent with Borg Warner.
Although the design isn't really new. Like I said, Aerodybe was already making them. Corky Bell was putting them on an NSX and getting boost at idle. There were people hydrolocking motors because of these things.
Old Nov 29, 2005 | 06:08 AM
Boostage's Avatar
Default Re: (Knightsport)
yeah that is a bit much, definatly dont want positive pressure at idle. I guess if we get the chance to run these we do what we do now, which is to run turbos way bigger than we need.
Old Nov 29, 2005 | 06:48 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knightsport &raquo;</TD></TR><TR><TD CLASS="quote">
Although the design isn't really new. Like I said, Aerodybe was already making them. Corky Bell was putting them on an NSX and getting boost at idle. There were people hydrolocking motors because of these things.</TD></TR></TABLE>
Yep, the Aeromotive Corky speaks of so highly in his book, I remember that thing although I only recall it being variable on the turbine end.
Old Nov 29, 2005 | 06:55 AM
El Chico
25 Year Member
Community Builder
Default Re: (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, the Aeromotive Corky speaks of so highly in his book, I remember that thing although I only recall it being variable on the turbine end.</TD></TR></TABLE>
It was only variable vane on the hot side.
Old Nov 29, 2005 | 07:26 AM
Everyones Hero's Avatar
Damn, and I'm stuck with this TD04 14g that poops out at 7psi.
Old Nov 29, 2005 | 07:34 AM
beepy's Avatar
Default Re: (Everyones Hero)
Nothing new. The Garrett GT-xx-V series turbos are all variable vane. It's nothing you would want to use in a custom application. The variable vane system requires you to very specifically match a turbo to the application, and in all cases it ends up being a turbo which is much smaller than people here are accustomed to using. The way it works is by altering the vane angle, you can alter the efficiency of the turbo. To limit boost, you drop efficiency until the turbo peters out. The turbo will spool faster than a non-vane turbo, but it will still have lag.
Old Nov 29, 2005 | 07:59 AM
karmadhi's Avatar
Default Re: (beepy)
something people can refer to your explanation
Old Nov 29, 2005 | 08:08 AM
Boostage's Avatar
what moves the vanes?
Old Nov 29, 2005 | 08:24 AM
done's Avatar
how cool is that?
i heard about this technology last year, isnt garrett developmenting something like this also??
Old Nov 29, 2005 | 08:28 AM
Si Shane's Avatar
Compressor A/R is almost always .7 because the A/R has very little effect on it. The writer does not know what they are saying and got caught misusing jargon: the compressor's (meaning the turbo's) turbine is what is variable or much more simply put the turbine is variable.
Having a variable compressor is not something you are going to see.
Old Nov 29, 2005 | 08:34 AM
*Boostwerks*'s Avatar
Yeah, I would think that the vains in the compressor would vastly KILL the efficency. I also can't really see why that would be beneficial in any sense.
However, the technology in the turbine, is awsome. I would love to see this technology make a very powerful sports car using a super small engine that gets great cruising gas mileage.
Old Nov 29, 2005 | 08:42 AM
m R g S r's Avatar
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote"> I would love to see this technology make a very powerful sports car using a super small engine that gets great cruising gas mileage. </TD></TR></TABLE>
why? ur gonna buy a porsche as ur DD? lol
jk i would if i had the $$
Old Nov 29, 2005 | 08:49 AM
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
jk i would if i had the $$ </TD></TR></TABLE>
lol...NO.
I have always wanted to see someone make a decently sized sports car with like a 1.3l turbocharged engine. Just think of it this way... 280WHP, a torque curve like a V8, and gets 40mpg cruising... . Whether or not that would be possible, and reliable would be the question. But this vain technology would surely help.
Old Nov 29, 2005 | 09:41 AM
El Chico
25 Year Member
Community Builder
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Nothing new. The Garrett GT-xx-V series turbos are all variable vane. It's nothing you would want to use in a custom application. The variable vane system requires you to very specifically match a turbo to the application, and in all cases it ends up being a turbo which is much smaller than people here are accustomed to using. The way it works is by altering the vane angle, you can alter the efficiency of the turbo. To limit boost, you drop efficiency until the turbo peters out. The turbo will spool faster than a non-vane turbo, but it will still have lag.</TD></TR></TABLE>
Echo?
It was already covered that this is not new. Infact it's 1980's technology.
The turbo's will have VERY LITTLE lag.
In some cases the original Aerodyne was causing positive manifold pressure at idle and causing hydro lock.
You won't see lag near ANYTHING we have now with this technology.
Old Nov 29, 2005 | 10:13 AM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">what moves the vanes?</TD></TR></TABLE>
A wastegate actuator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knightsport &raquo;</TD></TR><TR><TD CLASS="quote">Echo?
While lag will be somewhat less in a VVT than in a non-vane, it will still be significant if you use a large turbo. I can create a zero-lag turbo system right now, but nobody will buy it because it won't be able to support the HP people are after.
No gasoline engine in the world will make boost at idle. If it isn't making vacuum it will not idle. Period. By their very nature gasoline engines will intake air and fuel until the load on the engine is equal to the instantaneous torque generated in the engine. This is either done by increasing load or decreasing generated torque, as in idling. It is of course possible to make boost at idle speeds, but only if engine load is huge, at which time it isn't at idle, by definition.
I also don't understand how a turbo could cause hydrolock. Forced hydrolock very rarely occurs in engines, and the only times I have heard of it without accidental water intake were in nitromethane engines, where the AFR is like 1:1.
Modified by beepy at 7:25 PM 11/29/2005
Old Nov 29, 2005 | 11:02 AM
abmerop18's Avatar
Default Re: (beepy)
interesting...
RACEPAK
Jan 22, 2008 05:50 PM
b00stedbyFastrax
Jun 24, 2006 01:35 PM
discopotato03
Mar 22, 2005 09:41 PM
henryicecold3000
Jun 13, 2004 02:24 AM
AsianMullet
Oct 25, 2003 11:56 AM
