turbo problem
Old Nov 27, 2005 | 05:18 PM
marcussmith26's Avatar
Default turbo problem
I just got my turbo setup on (except FUEL PUMP)what will it do with out pump
setup
t3 turbo
3" down pipe
38mm wastegate
450cc injector
jg intake manifold
uberdata
still like 255lph fuel pump
I drove it about 100 yards it was spiting and sputing. I got the RPM's to about 5000
any ideals i'm going to put a fuel pump on i just haven't got it yet. just making sure this is the problem
Old Nov 27, 2005 | 06:40 PM
jlperformance's Avatar
Default Re: turbo problem (marcussmith26)
Marcus, I would say that you did not put your check valve in line on you map sensor yet, did you? At low rpms your stock pump should not be cutting out like that, give me a call tomorrow and I will check it out for you.
Old Nov 27, 2005 | 07:39 PM
93turbo16's Avatar
Default Re: turbo problem (jlperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlperformance &raquo;</TD></TR><TR><TD CLASS="quote">Marcus, I would say that you did not put your check valve in line on you map sensor yet, did you? At low rpms your stock pump should not be cutting out like that, give me a call tomorrow and I will check it out for you. </TD></TR></TABLE>
No need for a check valve, keep that thing off of there.
If you do anything, check plug gap and or spark plug wires.
Old Nov 27, 2005 | 08:05 PM
Default Re: turbo problem (93turbo16)
Oh my bad I forgot about uberdata!
Old Nov 27, 2005 | 08:19 PM
boosted k20's Avatar
um, u need to get ur car tuned
Old Nov 27, 2005 | 08:34 PM
BlueShadow's Avatar
Marcus,
Did you follow the correct procedure on how to make a basemap for those 450cc's? There's a huge thread on how to do that on the http://www.uberdata.org forums. However even if you made your basemap properly the fuel might still be a little off. You're gonna need a wideband to tell you what your AFR's are from idle up to 5000 RPM's. Also likse 93turbo16 was asking what is your plug gap?
asianspeed
Oct 21, 2005 09:40 PM
djnikko
Mar 7, 2004 09:47 AM
Cractos
20
Dec 16, 2003 08:16 PM
slow02ss camaro
Mar 30, 2003 04:04 PM
ninetyfourgsr
Jul 3, 2002 11:21 PM
