i have a problem with clevite beraing please help maybe i do something wrong
Old Nov 28, 2005 | 07:43 AM
ivt-t's Avatar
Default i have a problem with clevite beraing please help maybe i do something wrong
hi!
i have purchased std clevite bearing for my b16a1 engine.i bought eagle rods also.
i have measured the clearance between the bearings and the crank and there is 0,004inch.it is very much i think.
please help me if you can.
thank you
Old Nov 28, 2005 | 07:50 AM
beepy's Avatar
Default Re: i have a problem with clevite beraing please help maybe i do something wrong (civiccoupehybrid)
Main bearing: Journals Number 1, 2, 4, and 5 should measure between 0.0009 - 0.0017 inch, while Journal Number 3 should measure between 0.0012 - 0.0019.
Rod bearings: Differ by engine, but about 0.0015 - 0.0020.
If you in fact are getting 0.004 they are too loose. Are you measuring the clearance with plastigage?
Old Nov 28, 2005 | 08:09 AM
Muckman's Avatar
Moderator in Chief
Does Clevite sell thicker bearings sets like ACL does?
Your going to need some seriously thick bearings to get you within spec.
Old Nov 28, 2005 | 08:46 AM
ivt-t's Avatar
Default Re: i have a problem with clevite beraing please help maybe i do something wrong (Muckman)
i dont know exatly what is the problem.because i have ordered std beraings and the engine was fully working when i began to build it to turbo engine-
Old Nov 28, 2005 | 08:53 AM
beepy's Avatar
Did you use plastigage, and, did you use the correct plastigage for your range or readings?
If you use the wrong plastigage, your readings will be way off.
Old Nov 28, 2005 | 09:01 AM
ivt-t's Avatar
Default Re: i have a problem with clevite beraing please help maybe i do something wrong (beepy)
i have used dial bore indicator
Old Nov 28, 2005 | 11:56 AM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccoupehybrid &raquo;</TD></TR><TR><TD CLASS="quote">i have used dial bore indicator</TD></TR></TABLE>
dial bore indicator is good but always double check with plasigauge just to make sure.
Old Nov 29, 2005 | 03:05 AM
ivt-t's Avatar
Default Re: i have a problem with clevite beraing please help maybe i do something wrong (non-VTEC)
the problem is that the clearance between old bearing and the crank is 0,0023
Old Nov 29, 2005 | 04:55 AM
USDM 4G VTEC's Avatar
get OEM Honda bearings obly
the safe and true way to get the right clearances
coot_er
Nov 10, 2009 09:25 PM
smoovy
Jan 22, 2008 10:45 AM
y7turbo
Nov 1, 2007 08:21 PM
integra95
Feb 22, 2003 08:26 AM
Sonny
Jun 12, 2002 07:24 PM
