Recommend a good electronic boost controller
Old Nov 26, 2005 | 07:36 PM
Luchini's Avatar
Default Recommend a good electronic boost controller
I think my Turbo XS manual one hit the dust. It wont tune at all anymore. So im in the market for a new one. An electronic one this time. The idea of quickly switching boost while not having to get out of the car appeals to me. Not looking for a whole lot of options just basic and preferably a small sized one I can fit under the CD player.
Old Nov 26, 2005 | 07:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Recommend a good electronic boost controller (Luchini)
i have a blitz dual sbc spec r. it is a 1/4 din. it is bad ***, uses an awesome stepper motor. held 17 psi on the old drag kit and cannot wait to crank the bitch to 28 (damn 3 bar) you can shift on the fly. 4 preset settings.
Old Nov 26, 2005 | 07:57 PM
Luchini's Avatar
Default Re: Recommend a good electronic boost controller (boostedcivicsir)
Looks solid and small good find. Are these things alot harder to install then a manual one? Oh yea it wont interfere with my hondata s200? I was looking at the apexi one and it had like fuel controls and all that stuff.
Old Nov 26, 2005 | 08:31 PM
Mr. Badwrench
cake man. easy to install, a little harder than a manual, but overall easy. setting it up is a little tricky, getting the gain set right but once you get your 4 settings set, turning up or lowering the boost is like turning up your radio.
Old Nov 26, 2005 | 08:43 PM
onemanlan's Avatar
Except more dangerous
Old Nov 26, 2005 | 09:54 PM
Luchini's Avatar
Default Re: Recommend a good electronic boost controller (onemanlan)
Is boost spike a big problem with electronic ones?
Old Nov 26, 2005 | 10:13 PM
smoovy's Avatar
the Apex AVCR doesn't have controls for fuel. you can monitor, rpm, boost, speed, throttle response and a few others I can't think of and it does alot of stuff other controllers don't do. great boost controller but difficulty level between 1-10 would be a 8. not the easiest to use at all.
Old Nov 26, 2005 | 10:51 PM
jdm2teg's Avatar
Default Re: Recommend a good electronic boost controller (smoovy)
what you guys know about the greddy profec boost gauge because i am supposed tgo get on
Old Nov 26, 2005 | 11:09 PM
poid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luchini &raquo;</TD></TR><TR><TD CLASS="quote">Is boost spike a big problem with electronic ones? </TD></TR></TABLE>
once its dialed in it will hold boost no problem...i've only had it spike while it was learning the way the car boosts (ie first couple times after it was setup) but after that no spikes whatsoever
Old Nov 26, 2005 | 11:42 PM
.RTErnie's Avatar
Default Re: Recommend a good electronic boost controller (poid)
I have a Profec B II...i loved it until I used an Apex'i AVC-R...now I cant wait until I have gear dependant boost control. mmmmm.
Old Nov 27, 2005 | 12:54 AM
Sinner's Avatar
forum.TullosTech.com for details about our TullosTech EBC
Old Nov 27, 2005 | 06:18 AM
sikciv666's Avatar
Default Re: (Sinner)
BLITZ....
Old Nov 27, 2005 | 06:54 AM
Integra21's Avatar
Default Re: (sikciv666)
i like my blitz sbc-id - now that is set up right. Holds boost great
Old Nov 27, 2005 | 09:59 AM
Luchini's Avatar
Default Re: (Integra21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">I have a Profec B II...i loved it until I used an Apex'i AVC-R...now I cant wait until I have gear dependant boost control. mmmmm.</TD></TR></TABLE>
Gear dependent boost control? You can actually control how much boost there is in each gear? Damn. I dont think im ready for that yet.
Old Nov 27, 2005 | 10:25 AM
Makdaddynuge's Avatar
its awesome to help out on traction
Old Nov 27, 2005 | 10:36 AM
scottishdave's Avatar
Default Re: (Makdaddynuge)
Who makes a boost controller that can do gear dependant boost control? Will sytems like hondata do that?
Old Nov 27, 2005 | 10:37 AM
LSEGHATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">i have a blitz dual sbc spec r. it is a 1/4 din. it is bad ***, uses an awesome stepper motor. held 17 psi on the old drag kit and cannot wait to crank the bitch to 28 (damn 3 bar) you can shift on the fly. 4 preset settings.
Correct me if I'm wrong but the Spec-R can withstand 36psi due to it being 2.5bar
Old Nov 27, 2005 | 12:46 PM
onefstek's Avatar
AVC-R all the way
boost by gear
boost by rpm
boost by speed
two boost settings plus your wg setting (so 3 settings)
gain by rpm also
Old Nov 27, 2005 | 12:59 PM
LSEGHATCH's Avatar
What can the Apexi AVC-R boost to? You may have just changed my mind from the spec-r
Old Nov 27, 2005 | 01:24 PM
.RTErnie's Avatar
Default Re: Recommend a good electronic boost controller (LSEGHATCH)
I believe 3 bar at least. I know my ProfecB went to 33 psi.
Old Nov 27, 2005 | 01:51 PM
onefstek's Avatar
the avc-r comes with a 3 bar map sensor.
smoovy's Avatar
Default Re: Recommend a good electronic boost controller (RTErnie)
I love my AVCR but like I said before, it's not the easiest to use. takes a lil' TLC to use all of what the AVCR provides. gear depedent boost, RPM based boost, scramble boost, 2 different settings and can monitor all of what I said before and then some.
Old Nov 27, 2005 | 01:55 PM
was the avc-r 3 years ago the same it is now? asking because a guy has one for sale for cheap but its like 3 years old.
Old Nov 27, 2005 | 02:05 PM
smoovy's Avatar
the same features that are featured on the apex website should be the same as what he is offering. to be honest with you, I think it's the same from the day it came out to the one they have now. like the AFC and super AFC and all others. this is really the only one that they haven't changed. it's that far ahead of the crowd. it's been the same since day 1.
Old Nov 27, 2005 | 02:26 PM
cool thanks a lot
