T-25 help! Overboosting!
Old Nov 29, 2005 | 05:25 PM
VTcivicHB's Avatar
Default T-25 help! Overboosting!
Before I put on my turbo the actuator arm felt really stiff, I could get it to move, but I would have to put a lot of force on it, (internal wastegate) but I went and installed it anyways. Now instead of boosting the 8 psi its more like 15 psi. So my question is, is there a way to fix this without haveing to get a new wastegate and taking the turbo off the car? I know its a T25, is this a common problem?
Also on the way home from the tuner (Hour and half drive) I heard a popping noise when I shifted @ around 8 psi. I believe that is detonation? Should I tell the tuner to retard the timing some more, he couldn't give me fuel map graph so I'm assuming its just because its not fully tuned because of the boost spikes.
Thanks
Old Nov 29, 2005 | 07:49 PM
SOHCmaster's Avatar
yeah man my T-25 was hittin 12-15psi easy, first I just bent the wastegate rod and had it open early but was still around 10-12psi. I had to take it to get modified with an adjustable link to turn it down the boost..
If you cant find anything just weld the flapper door shut and go external.
Old Nov 30, 2005 | 05:06 AM
VTcivicHB's Avatar
Yeah I've seen the modification with the adjustable actuator. I think I might just trying and get ahold of another one. I fould one @ slowboyracing.com but its a 170$.
Old Nov 30, 2005 | 07:44 AM
Willie's Avatar
Default Re: (VTcivicHB)
Im running the same setup. My original actuator was hitting 15 psi. Try www.atpturbo.com they have a couple of low pressure actuators. If not weld the flapper shut.
Old Nov 30, 2005 | 10:26 AM
VTcivicHB's Avatar
I didn't see any for t-25's it was all for t-28's. Thanks for the link though, I don't think I wanna weld the flapper shut though and do the external wastegate, I don't want to have to get a new manifold/ wastegate, that gets pricy
Old Dec 1, 2005 | 08:29 AM
Willie's Avatar
I believe if you look theres a 6psi actuator which is the same one that came on my t25 for about $60. Or just by a universal adapter plate and mount the t28 one thats what i did.
Old Dec 1, 2005 | 08:37 PM
SOHCmaster's Avatar
did you try to bend the rod yet so it opens up sooner ?
Old Dec 2, 2005 | 10:26 AM
VTcivicHB's Avatar
I think that its just a faulty actuator, its like the spring is busted or gunked up, so rebending it wouldn't work I don't think.
I fould a guy that's sending me one for 8$ so hopefully this cures it but we'll see. The wastegate is between the manifold and the block so I can't really get to it unless I take the whole assembly off, which I'll do when I get the new actuator.
Old Dec 2, 2005 | 10:33 AM
scottishdave's Avatar
Is your car still making that wierd sound
Old Dec 2, 2005 | 05:24 PM
VTcivicHB's Avatar
Yeah, I think I figured it out. It only happens when the BOV goes off and when it is @ 5psi or greater. I figure that its just like a champagne bottle, its got all that pressure getting released at once, its bound to make a popping sound.
V-SPEC 1
Feb 19, 2013 07:43 PM
niCastro
Aug 26, 2007 07:45 AM
Type-X
17
Feb 7, 2005 09:04 AM
tig3rxiong
Aug 4, 2004 06:40 PM
ITSTOCK
Apr 14, 2004 07:37 PM
