boost creep help me
Old Nov 26, 2005 | 07:53 PM
night2's Avatar
Default boost creep help me
Ok this is the deal I have an ls turbo setup and about 2 months ago is was spiking to like 15 lbs well I found out that the wastegate was bad so I bought a brand new tial 38 mm last week with a 7 lbs spring and its creeping to 9 lbs. When I try to run out 3 gear the boost guage goes to 9 lbs but the car isnt going as fast as it should be. Ive replaced all of the vac. lines but it still creeps. Ive talked to everyone I could think and done research and no one seems to have any idea what it could be someone please help me. Thanks
Old Nov 26, 2005 | 07:55 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: boost creep help me (night2)
where are you catching the boost signal? from the manifold or off of the compressor? just curious.
Old Nov 26, 2005 | 07:57 PM
night2's Avatar
from the manifold
Old Nov 26, 2005 | 08:04 PM
Luchini's Avatar
Default Re: (night2)
Just curious is this a pre fab kit or a custom kit?
Old Nov 26, 2005 | 08:06 PM
night2's Avatar
its a rev hard stage 2 kit
Old Nov 26, 2005 | 08:18 PM
Mr. Badwrench
any way to get the boost signal from the compressor?
Old Nov 26, 2005 | 08:21 PM
night2's Avatar
I dont know a lot of the turbo setups people have a vac. line coming from the turbo but I dont have that.
Old Nov 26, 2005 | 08:28 PM
Mr. Badwrench
if it were me, i would start there. every kit i have setup if it didnt have a nipple off of the compressor, i drill and tap one, and all the kits i have installed, havent had any creep issues.
Old Nov 26, 2005 | 08:29 PM
night2's Avatar
could the boost creep cause my car to feel slower?
Old Nov 26, 2005 | 08:56 PM
sycamore
Guest
Posts: n/a
y didnt you get a bigger waste gate???
Old Nov 27, 2005 | 12:13 AM
R6E6I6D's Avatar
Default Re: (sycamore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sycamore &raquo;</TD></TR><TR><TD CLASS="quote">y didnt you get a bigger waste gate??? </TD></TR></TABLE>
that didnt help him at all.....
well yea like guy said either tap the turbo and go to ace hardware and pick up a 1/8" npt fiting and teflon it in there or if no tap a IC pipe close as u can to the turbo ... Id go with the turbo personally thats how my turbonetics is and have had no problems
Old Nov 27, 2005 | 10:49 AM
dpetro1's Avatar
i run a revhard manifold and a tial 38mm with no creeping issues. i have run vaccuum from the compressor and the manifold, both worked fine.
what is your complete setup? are you using a boost controller?
Old Nov 27, 2005 | 01:45 PM
night2's Avatar
its an ls turbo with pistons and rods, rev hard stage 2 kit, and no Im not running a boost controller.
Old Nov 27, 2005 | 02:59 PM
Cprace1's Avatar
what pound spring do you have in the wastegate a 38 should be plenty big, also what kind of gauge are you running? I have seen autometers go bad a read off, I would go to a dyno one that reads boost like a dyno dynamics or other see if you are really getting creap and if so if you are losing power because of it, if you are losing power the extra boost could be messing with the a/fs which could in turn make the car feel slower.
Old Nov 28, 2005 | 10:29 PM
R6E6I6D's Avatar
Default Re: (Cprace1)
O maybe u are having a similar prob to me,.... jsut trying to help ok here goes: my wastegate dump is not on... (being fabed just lazy) and with it of it is a little slower when the hot burnt gasses rush back into compressor. when i had a dump on it it was smoother/faster...
Old Nov 28, 2005 | 10:32 PM
JDMlyfestyle's Avatar
Doesnt the Revhard kit have a poor wastegate placement?
Old Nov 29, 2005 | 06:51 AM
Mr. Badwrench
Default Re: (JDMlyfestyle)
i believe you are thinking of the drag kit.
it looks like the revhard shares 1&2 where the drag only uses 1.
Old Nov 29, 2005 | 07:45 AM
dpetro1's Avatar
Default Re: (boostedcivicsir)
yeah the revhard isnt the "best" placement but better than drag.
like boostedcivicsir said it kinda shares 1&2. but i have never had any boost consistency issues on my sc34 at 7psi
Old Nov 29, 2005 | 08:38 AM
Cprace1's Avatar
Default Re: (dpetro1)
Interesting, so you do have a tial 38 on the car now correct and is it doing the same thing the old wastegate was doing?
Old Nov 29, 2005 | 08:47 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cprace1 &raquo;</TD></TR><TR><TD CLASS="quote">Interesting, so you do have a tial 38 on the car now correct and is it doing the same thing the old wastegate was doing?</TD></TR></TABLE>
i think the old wastegate was spiking while now he is just having a little bit of creep in the upper rpm's.
night2, what size exhaust are you running, i know big exhausts sometimes have creeping problems, i doubt thats it but im just throwing everything i can think of out there.
Old Nov 29, 2005 | 08:53 AM
night2's Avatar
my wastegate is on the other side pointing down on the downpipe, im running 2 and a half exhaust. And i do appreciate everyones suggestions i have been talking to some people and they say that its a fuel problem.
Old Nov 29, 2005 | 09:09 AM
dpetro1's Avatar
why would they think that a fuel issue would cause boost creep? its the wastegate's job to control boost and if your boost isnt consistent then something has to be going on with it. just to double check, you do have all the vaccuum lines on correctly right? (side port to intake manifold, top port open?) not to saying your an idiot or anything but **** happens. all banjo bolts are tight? what size line are you using?
Old Nov 29, 2005 | 10:03 AM
Cprace1's Avatar
yeah boost is bleeding off some where it should be consistant
Old Nov 29, 2005 | 05:58 PM
night2's Avatar
yeah all the vac lines have been replaced and double checked all bolt are tight, not sure on the the size of the line off hand.
1fastlude1
May 2, 2008 01:40 PM
W.Zero
Jan 16, 2005 02:49 PM
boosted-delslow
Dec 6, 2004 05:01 PM
nigel
Aug 7, 2003 12:08 PM
DIRep972
Jan 15, 2002 10:13 AM
