TOTAL TIMING ON A P75 ECU ???
Old Nov 29, 2005 | 11:21 AM
99lspwr's Avatar
Default TOTAL TIMING ON A P75 ECU ???
If anyone knows the exact amount of total timing advance of a stock p75 ecu that would be very helpful to me at this point of my "creative tuning" setup... I have an idea that it somewhere between 27-30 deg at full advance, but I want to be 100% sure... thanks!!!
Old Nov 29, 2005 | 11:52 AM
adseguy's Avatar
Default Re: TOTAL TIMING ON A P75 ECU ??? (99lspwr)
on a p75 which is an OBD1 LS ECU at o vaccum and highest revs you are at 27.75. Why do you want to know? Are you advancing timing? I've done 2-3 degrees with good octane and noticed only mild results on an NA app. GL
Old Nov 29, 2005 | 11:59 AM
99lspwr's Avatar
Default Re: TOTAL TIMING ON A P75 ECU ??? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">on a p75 which is an OBD1 LS ECU at o vaccum and highest revs you are at 27.75. Why do you want to know? Are you advancing timing? I've done 2-3 degrees with good octane and noticed only mild results on an NA app. GL</TD></TR></TABLE>
No, I am pulling timing (mechanically) with a btm and I will be pushing the stock engines limits with some old school technology, so I wanted to be as accurate as possible from my start point.....Thanks for the confirmation though...
Old Nov 29, 2005 | 12:47 PM
boosted k20's Avatar
around 27 degrees. i ran my LS with 11:1 CR at 30* timing making good power
Old Nov 29, 2005 | 01:40 PM
99lspwr's Avatar
Default Re: TOTAL TIMING ON A P75 ECU ??? (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">around 27 degrees. i ran my LS with 11:1 CR at 30* timing making good power</TD></TR></TABLE>
So it looks like my estimation was fairly close...So basically if your base is set at 16 deg btdc, your looking at 27-28 deg total...correct???
Old Nov 29, 2005 | 01:59 PM
blackeg's Avatar
according to the base bin's in uberdata: 28.75 degrees at .35vacuum from 5krpms plus
Old Nov 29, 2005 | 02:01 PM
99lspwr's Avatar
Default Re: TOTAL TIMING ON A P75 ECU ??? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">according to the base bin's in uberdata: 28.75 degrees at .35vacuum from 5krpms plus</TD></TR></TABLE>
Where is your base timing set at??
Old Nov 29, 2005 | 02:25 PM
blackeg's Avatar
mine was at 16* on the crankshaft. then i ran like a .9*/lb retard off the 28.75, and made changes from there
Old Nov 29, 2005 | 03:23 PM
99lspwr's Avatar
Thanks for all the replies...
the.hamburglar
Oct 14, 2004 11:37 AM
integrx
May 12, 2004 02:48 PM
SpeedracerS4
Jan 27, 2002 10:57 PM
Black R
Dec 19, 2001 09:29 PM
01PYTypeR#1140
Jul 17, 2001 06:33 PM
