can i run type r cams
Old Nov 25, 2005 | 01:33 PM
shitycivic's Avatar
Default can i run type r cams
can i run type r cams in my b16 whit it turbo will it be ok will be boostin 6-8lbs what you guys think thanks
Old Nov 25, 2005 | 01:54 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: can i run type r cams (shitycivic)
it will be fine, just get it tuned, although i dont think the gains at those low psi levels would be worth it
Old Nov 25, 2005 | 01:59 PM
shitycivic's Avatar
Default Re: can i run type r cams (wantboost)
would it be better with gsr cams
Old Nov 25, 2005 | 02:12 PM
wantboost's Avatar
Who is Mr Robot?
the top end wouldbe a little better but at the power levels you are pushing i would put the money elsewhere.. like building the motor
Old Nov 25, 2005 | 02:29 PM
s2kdre's Avatar
just get the ctr's 00-01 itr cams those are more than good enough for ur set up.
Old Nov 25, 2005 | 02:30 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: can i run type r cams (jdmhonda)
yes they are good but he doesnt really need them at this point... for the boost hes runnning the stock cams are more then enough.... he needs to focus on putting the money into other parts of his motor
Old Nov 25, 2005 | 05:05 PM
D@nnY's Avatar
thye are good for making power iif you rev the **** out of that b16 ....
Old Nov 25, 2005 | 05:22 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: can i run type r cams (D@nnY)
yea, but based on his boost levels i dont think the motor is built to handle high rpm operation
hellakapps
Oct 18, 2007 01:05 PM
civic_36
May 10, 2006 04:51 AM
99b18
Dec 27, 2004 06:32 PM
4ghatch
Jan 30, 2003 05:24 PM
JustVTEC
Sep 19, 2001 08:17 AM
