is this rod useable?
Old Nov 25, 2005 | 02:50 PM
Brad's Avatar
Default is this rod useable?
Looks like someone tried to pry it or something. Can I sand it down or something?
Old Nov 25, 2005 | 02:53 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: is this rod useable? (Brad)
what kind of rod? you could have someone rehone it
Old Nov 25, 2005 | 02:58 PM
Brad's Avatar
Default Re: is this rod useable? (wantboost)
eagle rod. It looks like there would still be a gap after a hone.
shortyz21's Avatar
why potential sacrifice your motor over a 250$ set of rods?
get some new ones..
Old Nov 25, 2005 | 03:07 PM
JDM_Risa's Avatar
Default Re: is this rod useable? (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">why potential sacrifice your motor over a 250$ set of rods?
get some new ones..</TD></TR></TABLE>
true that...its like peace of mind knowing everything in your motor is new or up specs rather then that slight doubt that something might go wrong
Old Nov 25, 2005 | 03:17 PM
BigMoose's Avatar
Standard disclaimer, without having the rod in my hand its hard to know for sure... that said, the cap looks like it drew down solidly by the looks of the split line, so a careful dressing with a shaped oil stone is likely appropriate.
Old Nov 26, 2005 | 09:42 AM
earl's Avatar
Default Re: is this rod useable? (BigMoose)
Same disclaimer as BigMoose
I think the rod is fine and the gap will not hurt strength
Old Nov 26, 2005 | 11:59 PM
LilCivic04's Avatar
why don't you just call the manufacturer and just get one rod, because its not worth the time to take it all apart if it fails.
Old Nov 27, 2005 | 03:41 AM
RACEPAK's Avatar
Default Re: is this rod useable? (LilCivic04)
i "think" you can trust earl...
Old Nov 27, 2005 | 06:52 AM
JDMCRX's Avatar
Default Re: is this rod useable? (RACEPAK)
Yeah id say try calling the manufacture see how much it is but looks like someone may tried prying it take a small file and clean it up.
Old Nov 27, 2005 | 09:53 AM
earl's Avatar
Default Re: is this rod useable? (JDMCRX)
I don't think that mark has anything to do with prying. It is just part of the manufacturing process. It probably came that way when it was new.
Old Nov 27, 2005 | 11:58 AM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">i "think" you can trust earl... </TD></TR></TABLE>
Old Nov 27, 2005 | 12:42 PM
HYBRID_H@TCH's Avatar
Default Re: is this rod useable? (t67civic)
I have seen that mark before..
when people who dont 100% know what they are doing and they tap the piston down in the block the big end hits the crank and makes that mark..seen it way to many times..
with that said I have built more than a hand full of engines that the first person trying to install did this to..just took the rods to the machine shop and had a very slight hone done on them and was good to go..
RACEPAK
Nov 3, 2008 06:52 AM
importboi22
Mar 8, 2004 07:52 PM
93LSivic
Feb 4, 2004 01:23 PM
AVATAR
Nov 5, 2003 07:00 PM
Hoosier Daddy
Oct 27, 2003 09:37 PM
