My Boosted CRX buildup! Lots of pics.
Parts that i have gathered in the last few weeks...
I will start very soon.. And i mean VERY soon.. The reason (heres a pic of the car)
Snow already.. Damn its only november.
I will keep you updated as more parts come/Get installed
Re: My Boosted CRX buildup! Lots of pics. (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Looks funnier w/o caption - snowing on May 4th!
Any other info, or do we have to search for it?
went to go do my swap today....woke up...****** snow on the car!!
Ohh well...I'm a crazy new yorker...snow never stopped me before..why noW?!?!?
Re: My Boosted CRX buildup! Lots of pics. (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">turn your wipers off before you turn the car off!</TD></TR></TABLE>
It was snowin a blowin so hard i just wanted to get inside!
Some details incase your curious...
GSR block, CTR head, GSR cams. ARP head studs. Stock otherwise..
JG or Blox IM, STR 70mm TB, RC 750's, Aeromotive FPR
T3.T4 turbo, Ramhorn mani, 38mm gate, 50mm bov, 3" dp+exhaust
Fullrace traction bars, 92 civic half rad, Precision IC, 2.5" Chargepiping...
Wideband... Undecided on brand, Boost, EGT, Datalogging with Cromepro.
Other details.. gm3bar, hondata IM gasket, oil press, wtaer temp.. Etc.
Hoping for something around the 300whp mark.
What would you all recommend..? Blox Intake manifold or JG for my setup? Blox would save me some cash though, blox any good for turbo?
If the comment on the garage was towards me, i have a very large shop about 50 ft infront of the car. thats where the work will be done. I dont work in the cold!
Thanks!!
Modified by HamiltonRex at 9:38 PM 11/24/2005
Thanks!!
Got more parts in the last couple weeks!
Lm1 Wideband
JG VictorX Intake Manifold
Precision 780cc Injectors
3" stainless exhaust
Material for 2.5" Chargepiping, and 3" Downpipe
350Hp (small yes i know) Precision Intercooler.
JK Motorsports Traction bars
Greddy Boost and EGT gauges.
Basemap From 93TurboB16
3Bar GM Map
Parts left...
Boost Controller
Oil/Fuel Lines
STR fuel rail
walbro 255lph Pump
Silicon Charge piping connectors
Throttle body
92-00 Civic Rad
Aeromotive FPR.
Sorry no new pics! Car goes into the garage Jan1st!!
Lm1 Wideband
3Bar GM Map
Parts left...
Boost Controller
Oil/Fuel Lines
STR fuel rail
walbro 255lph Pump
Throttle body
92-00 Civic Rad
Aeromotive FPR.
lookin good man! good luck doing anything in winter haha i was working on my car today (in garage - nonheated) and holy **** im lucky i still have all my fingers
Re: (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">i would say screw the throttle body (unless your motor doenst have one) and get a larger intercooler.</TD></TR></TABLE>
Why so? do you think that the small precision unit wont support my 300whp goal?
This will be my setup for next year, after that i will be upgrading internals, FMIC, and turbo and shooting for 400 depending on how this setup treats me!
yes working in the cold is very large, lucky i have a very large heated shop (wood stove), so my fingers will stay intack
Re: (HamiltonRex)
plenty of people make decent to big numbers on a stock throttle body, if u need a larger one i would contact maxbore and have mine rebored. Its not a bad thing, imo the money could be spend else where like a larger intercooler. If you wanna upgrade later think ahead now, you would out grow the intercooler way before you outgrow you tbody.
Yeah.. Thing is i have a stock 1st gen b16 one.. 58mm.
If you think ill be okay then ill stick with that, as i have no prior experience. Ill spend the extra cash on tuning.
Ther intercooler on the other hand, i already bought new. So ill use it for now.
Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">Yeah.. Thing is i have a stock 1st gen b16 one.. 58mm.
Ther intercooler on the other hand, i already bought new. So ill use it for now.</TD></TR></TABLE>
yeah or send it to maxbore for a 100 bucks, i made 265 whp on a mustang dyno. This was a stock b16a1 with a first gen t body, so i know you will make your mark. After you get teh bug and 300whp is slow you want 500 next, espcally if you rebuild. Thats why i think you should get a larger intercooler but its your car and money and not mine lol.
How does that manifold clear on a crx? any pic of it on the car?
No no pics, no test fit yet..
It should clear the hood fine, the guy who makes it knows his ****! SillySohc. I know I may have to modify the upper rad support to run the WG where it is now..
Its gonna be tight but ill make it work!
Edit. Also if you look at the fullrace mani, which fits fine. You will notice mine places the turbo a bit lower, and the runners sit lower then the full race ones!
See pic here
http://www.full-race.com/catal...d.jpg
The turbo t3 flange sits higher to the bottom of the head flange then mine.. so the runners must be higher.. Or the same.
And it looks like i will be fine with block clearance!
See pic here
Ok..
Update.
Car was in the garage yesterday, got it up on stands. Old exhaust off, crossmember etc. Fit the manifold (fits good) and turbo and wastegate. All fits OK..
Tommorow, i plan to bolt up my crossmember, and fit half rad.. Then i will start fabbing up the 3" downpipe, along with installing the 3" exhaust setup
Ill post a bunch of pics up tomorow
Update.
