how much power/boost can a deltagate hold??????????
Who is Mr Robot?
Re: how much power/boost can a deltagate hold?????????? (civicjdmb16a)
i wouldnt use it to begin with... the design is shitty. it boost creeps like a ****. just save up at get a tial
There's nothing wrong with a Deltagate, I ran one for almost 3 years, no issues, the dude I sold it to is running it with no issues. The main thing you have to realize is that you have to size your gate to your application, the Deltagate is only something like 25mm, so it's a small valve. Of course if will cause creep if you use it on the wrong application. Check the Turbonetics website for application specs, if it's too small, go with one of their bigger gates, then just get the spring you need for your boost level.
If you are running a big turbo and low boost, go with a bigger wastegate valve to avoid boost creep.
Re: how much power/boost can a deltagate hold?????????? (wantboost)
yes i was,but it was in a good way.the most i have put on
a delta gate is 350.never had any boost creep or anything.
harv
wantboost
harv
wantboost
Re: how much power/boost can a deltagate hold?????????? (1700anddroping)
I did about 250 with a Deltagate with no creep even with a Drag manifold. Ran a MBC off the turbine housing and never had a problem other than the occasional 1-2 psi spike when very cold on first boost.
Broken Gearbox
06-08-2003 02:12 PM
