Turbo whores... If you've owned more than 3 turbo's let me know what you like!
Turbo ******... If you've owned more than 3 turbo's let me know what you like!
since you've obviously had a boosted car for a while...owning three different turbos...let me know what you like the most after experiencing all three.
Something rather small... 14b, t-25, T3, GT28RS
something rather medium sized t3/t4 .50 trim all the way to .82AR .60trim's
something big T4, t3/T67, GT30R-40R, PT63 etc
I've got a t3/to4s with a .63AR turbine 76 trim exhaust... .70AR compressor 60trim making ~400whp/390ft lbs Im wondering should I go bigger....go smaller or am I juuuuuust right. I think for the street 350 whp is about all that I really want. Somewhere near that with an gear dependant boost controller...so I can get traction down low. Also a nice GT35R could be a riot. let me know what YOU think you liked the most after being through a couple of turbos. And why
Re: Turbo ******... If you've owned more than 3 turbo's let me know what you like! (RTErnie)
holy #@$% .... you are making 400hp and 390ft lbs??? what motor is this on?
I have owned a very small T3.....48 A/R and it was ok.
I am greedy and want mad powah so now I have a T4/T67 with a .70 A/R and I still like it except for not tractioin in first gear and sometimes second on the street.
Re: Turbo ******... If you've owned more than 3 turbo's let me know what you like! (Da K00l Aid Mayu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da K00l Aid Mayun »</TD></TR><TR><TD CLASS="quote">holy #@$% .... you are making 400hp and 390ft lbs??? what motor is this on? </TD></TR></TABLE>
My guess would be an ls/lsv. If he's makin that in the neon, then I have absolutely no idea.
I've owned t3/t4 w/ .48 a/r, .63 a/r stage 3, t3/t4 with stage 5 1.0 a/r, t3/60-1 w/stage 5 .63 a/r, t4/t67 p trim .58 a/r. I like the T4/T67 the best of all.
Now I have GT42R.
I would go with T4/T67.
Now I have GT42R.
Re: Turbo ******... If you've owned more than 3 turbo's let me know what you like! (Turbocivic94)
thanks :-D .58AR T4/T67 I was looking at the T3/T67's from full-race, but I wasnt sure if should go with a small T4 turbine...or a .82AR t3.
i had a revhard custom turbo kit with to4e/t3 (unknown what trim it was 1998 and i was a noob)
hytech pt67/T4
Full race top mount gt4067
the best power band was the hytech pt67/t4
the smallest turbo i would ever go on a honda is a gt35R / t3
hytech pt67/T4
Mr. Badwrench
first:
87 t type stock t3 went 14.7
when it failed went with a TE 32E guessed 435 rwhp good for 11.81 in a 3400 lb car
second:
to4b drag kit, 330 fwhp 17 psi with a slipping clutch,
and now a t3-t67 will let you know the results.
second:
Re: Turbo ******... If you've owned more than 3 turbo's let me know what you like! (boostedcivicsir)
I've had:
t3 .42/.48 (stock LS)
t3/to4e .63/.50(Stock LS)
t3/to4e .63/60(GSR)
t4/to4e .80/.70(Built GSR)
I liked the straight t3 due to it's immediate spool and instant power but, the T4 had the best top end. I guess it all depends on your goals and what the car will be used for.
Phil
t3/to4e .63/60(GSR)
Phil
