need help with AEM 3.5 bar map sensor
Old Nov 26, 2005 | 02:19 PM
Turbocivic94's Avatar
Default need help with AEM 3.5 bar map sensor
I have AEM 3.5 bar map sensor. I was wondering if anyone can help me get 5 bar map for it. also I need the plug for it. Thanks
Old Nov 26, 2005 | 03:42 PM
SlowReaction's Avatar
Default Re: need help with AEM 3.5 bar map sensor (Turbocivic94)
I have no idea what your trying to ask. Do you mean trade a 3.5 for a 5?
Old Nov 26, 2005 | 05:09 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">I have no idea what your trying to ask. Do you mean trade a 3.5 for a 5?</TD></TR></TABLE>
^^^ x2
You're gonna be boostin &gt; 29psi???
Old Nov 27, 2005 | 05:37 AM
Default Re: need help with AEM 3.5 bar map sensor (SlowReaction)
That's what I'm trying to say. I wanted to see if anyone wants to trade my 3.5 bar map for their 5 bar map. It never been used.
I had 5 bar map on my previous setup. I bought 3.5 bar first then I end up buying 5 bar map so I can boost over 35psi.
Where can I find the harness for it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">
You're gonna be boostin &gt; 29psi???</TD></TR></TABLE>
GT42R
Old Nov 28, 2005 | 05:53 AM
anyone?
Old Nov 28, 2005 | 07:45 AM
Boostage's Avatar
isnt 3.5 bar 51psi?
Old Nov 28, 2005 | 07:58 AM
Default Re: need help with AEM 3.5 bar map sensor (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">isnt 3.5 bar 51psi?</TD></TR></TABLE>
3.5 bar= 35psi
3 bar= 29psi
Old Nov 28, 2005 | 08:20 AM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">
3.5 bar= 35psi
3 bar= 29psi</TD></TR></TABLE>
Unless I am miscalculating..
14.7 x 2.0= 29.4psi (2 bar)
14.7 x 3.5= 51.4psi (3.5 bar)
as far as I know 2 bar is 29psi not 3 bar.
^^^ boost guage max boost is 2.0 bar, by your calculations thats only 14psi. I am almost positive that you think 3bar=29psi because 3 bar map sensors wont read past 29psi. as far as I know Map sensors are rated with atmospheric pressure also in mind. basically you dont count the first bar. so a 3 bar sensor (44.1psi) will only read 2 bar of boost (29.4psi) while a 3.5bar sensor (51.4psi) will only read 36.7psi of boost.
Old Nov 28, 2005 | 08:44 AM
Boostage's Avatar
I was correct according to this..
http://www.soilmoisture.com/formulas.html
2 bar is 29.4psi
3 bar is 44.1psi
5 bar is 73.5psi
so as far as MAP sensors go if you dont include atmospheric pressures. a 3 bar map sensor will read up to 29.4psi and and 3.5 bar will read up to 36.7psi and a 5 bar will read up to 58.8psi
Old Nov 28, 2005 | 08:53 AM
seen4ever's Avatar
Default Re: (Boostage)
i wouldn't say you are overly right, he said the 3.5bar would only allow him to read 35psi or so, which is true, it reads 51psi, but 14.7 of that is used during vacuum. so inorder to boost higher than 35 he needs a 5bar map sensor, so he can boost up to 45psi
Code Blue's Avatar
not only that but this is the wrong forum to be posting a WTT post. This should be in hondamarketplace.com.
ricanzxrebel
Dec 19, 2008 04:47 AM
b18 hatch mike
Aug 29, 2008 09:33 PM
Greg H
Sep 23, 2006 06:58 AM
RACEPAK
Jul 23, 2006 02:32 PM
turboeg77
Feb 26, 2006 04:18 PM
