Weird ECU code, help please...
Old Nov 29, 2005 | 05:33 PM
Dr Pooface's Avatar
Default Weird ECU code, help please...
Trying to get my car running. Wrote a basemap in uberdata. Car starts but runs real rough, pig rich. Check engine light goes on. When I check the code I get two long flashes and then a steady light, the code does not repeat. Is that right, I thought the code was supposed to repeat, but if not I guess I'm getting a code 20 which is "Electrical load detector". What does that mean?
Setup:
b18c5
p28 with uber
55lb injectors
3bar
Old Nov 29, 2005 | 06:08 PM
xenocron's Avatar
Default Re: Weird ECU code, help please... (Dr Pooface)
I guess you are using a Canadian ECU? Most of them dont have ELD...disable it in Uber and see what happens.
Old Nov 29, 2005 | 07:35 PM
93turbo16's Avatar
I would say try a new map. What version of uberdata are you using?
Old Nov 29, 2005 | 07:44 PM
Dr Pooface's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">I would say try a new map. What version of uberdata are you using?</TD></TR></TABLE>
Version 1.7R2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">I guess you are using a Canadian ECU? Most of them dont have ELD...disable it in Uber and see what happens.</TD></TR></TABLE>
Ya, ECU is canadian. I didn't even notice the ELD box in uber, thanks I'll give that a whirl.
Old Nov 29, 2005 | 07:46 PM
93turbo16's Avatar
Yep, disable the eld.
Did you start with a new map for version 1.7R2? It has different fuel modifiers in then the other versions, you have to start clean from a GSR map. My car did the same thing during testing it.
Old Nov 29, 2005 | 08:01 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Check engine light goes on. When I check the code I get two long flashes and then a steady light, the code does not repeat. </TD></TR></TABLE>
weird... try crome. if it does the same thing than i bet you have a hardware problem..
Old Nov 29, 2005 | 09:23 PM
Dr Pooface's Avatar
Default Re: Weird ECU code, help please... (2point2)
Reburned the chip with the ELD disabled. No CEL now, but crappy missing super rich idle. My basemap skillz need work.
bmoua
Dec 29, 2007 09:08 PM
211811518
10
Sep 9, 2006 12:57 PM
barry11j
Aug 3, 2004 03:07 PM
iwhichisme
Apr 1, 2004 05:41 AM
AMG
Sep 2, 2003 07:03 AM
