Where to Get DP Flange for SC61?
I have the 4 bolt SC61 and after much searching I cant find a straight answer on where to get a good downpipe flange for it. I checked ATPturbo but the 2.5" is a little small and covers up the outlet a good bit. I have 3" piping for the downpipe and I'm trying to find a flange that will work. I see I may need a transition to use the 3" dp.
So basically Im looking for a flange for the SC61 so I can run a 3" dp without interference. Stainless steel would be nice too but not neccessary.
Re: Where to Get DP Flange for SC61? (2001ZincSR)
atpturbo has a 3" 4 bolt flange too http://www.atpturbo.com/Mercha...e=FLS
They have a disclaimer though that says this: * This flange is used for the newer GT housing with the long neck discharge and 3" ID opening. If using GT/T3 housing with shorter discharge neck and 2.5" ID opening, use P/N ATP-FLS-032 flange.
Re: Where to Get DP Flange for SC61? (BlueShadow)
yeah thats the problem, ATP-FLS-032 overlaps the outlet but lines up with the bolt holes, but Im affraid ATP-FLS-013 will not line up to bolt to the the turbo.
maybe you can take the flange to a machine shop and have them port match the flange and your turbine discharge?
I bought my JS series 5 bolt flange from ATP. I can put a 3" pipe right onto it and it tapers down to 2.5". The 2.5" inner matched up perfectly with my old T3/T04E, but with my new SC61 the inner part is a little too small. So I'm gonna take it to a shop and have them enlarge the inner diameter a little bit so it matches my SC61.
