running larger studs for the head?
Old Nov 27, 2005 | 05:03 PM
igo4bmx's Avatar
Default running larger studs for the head?
d series motors are imfamous for headgasket issues, and I may be facing one...
it seems the head can lift under boost....
I was wondering if drill and tapping the block for larger studs would help, since there would be a larger mechanical advantage, more friction in the threads, and more meat to the stud to hold the head down?
any thoughts?
Old Nov 27, 2005 | 05:10 PM
phatrick2332's Avatar
ive thought about running ls head studs before, cmon, someone answer this guys question
Old Nov 27, 2005 | 05:13 PM
80884's Avatar
Default Re: running larger studs for the head? (igo4bmx)
I'm sure it would help. I run 1/2" arp stud on my Bseries. (long story)
Do you run studs now or the stock bolts? I'm assuming you have studs now but i figured i'd check.
Old Nov 27, 2005 | 05:16 PM
igo4bmx's Avatar
Default Re: running larger studs for the head? (80884)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80884 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure it would help. I run 1/2" arp stud on my Bseries. (long story)
Do you run studs now or the stock bolts? I'm assuming you have studs now but i figured i'd check.</TD></TR></TABLE>
arp head studs with OEM headgasket
look like the studs in my car loosened up a bit from the spec torque....
i tightened them up, but one wasn't tighten (aka threadsw maybe being pulled out....)
so i might do a timesert, but wondered if just having thicker studs would help alot
Old Nov 27, 2005 | 05:58 PM
RMS's Avatar
RMS
there are a few b-series doing that. might not be a bad idea for the ds, too. especially with everyone overtorquing the arps for more clamp (and damaging threads).
if you go to a standard thread arp has lots of options for lengths.
Old Nov 27, 2005 | 06:38 PM
earl's Avatar
I can't imagine this helping unless you are boosting over 40 lbs. Standard ARP's should be fine.
Old Nov 28, 2005 | 01:59 PM
80884's Avatar
Default Re: running larger studs for the head? (earl)
His head is lifting with the current ARP studs. My guess would be the block is what is letting go (the threads) and not the studs. Thats why my engine has the 1/2" studs because the stock threads got messed up, not because i needed to be able to hold more boost. Just my thoughts.
Old Nov 28, 2005 | 03:52 PM
dfoxengr's Avatar
check all the thread in the block. then fix the bad ones.
thats one of the bad things about aluminum blocks...
Jared's Avatar
is your block sleeved?
Old Nov 28, 2005 | 03:56 PM
igo4bmx's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">is your block sleeved?</TD></TR></TABLE>
stock sleeves...
Old Nov 28, 2005 | 04:03 PM
80884's Avatar
Default Re: (igo4bmx)
Get another block. If there is no special work done to your current block then it's not really worth trying to fix it, easier to just get another block.
Old Nov 28, 2005 | 04:19 PM
igo4bmx's Avatar
Default Re: (80884)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80884 &raquo;</TD></TR><TR><TD CLASS="quote">Get another block. If there is no special work done to your current block then it's not really worth trying to fix it, easier to just get another block.</TD></TR></TABLE>
it seems to be it would be easier to use the timserts, than getting a spare block, getting it bored and honed and taking every single thing apart
Old Nov 28, 2005 | 04:46 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">
stock sleeves...
my personal theory is that the majority of sohc headgasket problems stem from swaying stock sleeves.
Old Nov 28, 2005 | 04:56 PM
ccfab's Avatar
Default Re: (Jared)
others see the light... fantastic
Old Nov 28, 2005 | 06:29 PM
platinum00's Avatar
Default Re: (Jared)
my personal theory is that the majority of sohc headgasket problems stem from swaying stock sleeves.</TD></TR></TABLE>
I agree, I had the head lifting problems until Benson leaved my block.....
I tried everything under the sun to get the stock sleeves to work.
Less timing, more timing, different torque specs, different head gaskets, sealer, no sealer, etc..........
One thing that does help or at least i got a couple more lbs of boost out of her before it blew was pre tightening the head studs to 15lbs before putting the head on and then torqueing them to in the following sequence. 20, 40, 65, 70lbs
They must move or expand under boost causing the head gasket to blow.
platinum.
kornerk12
Feb 7, 2007 09:03 PM
Fatty_1775
Feb 9, 2006 11:02 AM
Dublocivic
May 14, 2004 03:38 PM
iperez
Feb 11, 2004 07:21 AM
baonest1
Oct 17, 2002 06:29 PM
