Just dandy...
Old Nov 25, 2005 | 08:55 PM
mike93eh
Guest
Posts: n/a
Default Just dandy...
just got back from street tuning my d16z6 with greddy kit on 10psi. well i got it about halfway tuned and ran into a problem. my brand new stage 1 exedy clutch kit does nothing but slip in boost. i got this awhile back because my oem clutch was slipping on 5psi and it worked great up until now.
so whats a good clutch for a dseries making approximately 200whp? maybe a little above just in case. nothing too expensive.
thanks
Old Nov 26, 2005 | 06:15 AM
TurboCoop's Avatar
Default Re: Just dandy... (mike93eh)
I have an exedy 3 puck on my b series and its holding up great. Look into one theyre cheap too.
Old Nov 26, 2005 | 06:21 AM
nsxmatt's Avatar
A oem Exedy clutch should not slip in boost at your power levels, especially on the street. Not sure what your problem is but I doubt it's the ability of the clutch.
Old Nov 26, 2005 | 07:34 AM
mike93eh
Guest
Posts: n/a
Default Re: Just dandy... (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">A oem Exedy clutch should not slip in boost at your power levels, especially on the street. Not sure what your problem is but I doubt it's the ability of the clutch.</TD></TR></TABLE>
well it is, BAD.
the clutch had no slippage at all until tonight when i turned te boost up to 10psi from 5psi. now all it does in boost is slip.. i go no where. i can smell it a mile away and youre gonna tell me it isnt my clutch??
Old Nov 26, 2005 | 08:18 AM
mike93eh
Guest
Posts: n/a
whatd do you all think of the ACT HC5-XT00?
Old Nov 26, 2005 | 12:02 PM
mike93eh
Guest
Posts: n/a
Default Re: (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">whatd do you all think of the ACT HC5-XT00?</TD></TR></TABLE>
any thoughts on this? i just ordered it..
Old Nov 26, 2005 | 12:50 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">i can smell it a mile away and youre gonna tell me it isnt my clutch??</TD></TR></TABLE>
I did hundreds of 8500rpm launches on slicks with my stock Exedy clutch with alot more power than your making. I find it hard to believe it would just start to slip on the street unless there was another problem like riding the clutch, slave cly, mast cly, input seal leaking on the disk, or any number of things. But whatever, you ordered a new clutch so good luck.
Old Nov 26, 2005 | 12:51 PM
93turbo16's Avatar
About any sprung 6-puck will work..
Clutch specialties
Pro Clutch
ACT
Old Nov 26, 2005 | 12:56 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">I did hundreds of 8500rpm launches on slicks with my stock Exedy clutch with alot more power than your making. I find it hard to believe it would just start to slip on the street unless there was another problem like riding the clutch, slave cly, mast cly, input seal leaking on the disk, or any number of things. But whatever, you ordered a new clutch so good luck.</TD></TR></TABLE>
i thought it would hold no problem too... the clutch was about 1500 miles old, it was broken in, nothing wrong with my master or slave. it holds just fine up to 5psi and over that it just spins.. maybe something broke.. i dont know ill see once i pull the tranny off.
Old Nov 26, 2005 | 01:12 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">whatd do you all think of the ACT HC5-XT00?</TD></TR></TABLE> I have had only but incredible luck with ACT. So have all of my buddies. I loved the XtSS. I just went to the XTreme 6 puck for the new setup. ACT gets a from me
Old Nov 26, 2005 | 01:28 PM
Bailhatch's Avatar
Default Re: (ladysman)
why did you get the OO disc?
Old Nov 26, 2005 | 01:49 PM
mike93eh
Guest
Posts: n/a
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">why did you get the OO disc? </TD></TR></TABLE>
why? whats wrong with it?
Old Nov 26, 2005 | 08:27 PM
HiProfile's Avatar
IIRC, the OO is the normal street disc, no copper shavings in the disc material. Meaning a greater chance of heat/power making it slip. If that clutch goes too, I wouldn't be blaming it on the clutch. I've seen lots of people shift who think they're good - most of them I wouldn't let drive my car double-clutching. Not to point the finger, but make sure you look at EVERYTHING when you change the clutch. Flywheel step within factory spec? Master/slave allowing slippage? Bearings are known to go bad in d-series trannies, along with seals. There's also the fact that the smallest amount of water can make a clutch slip easily.
Old Nov 26, 2005 | 08:57 PM
sycamore
Guest
Posts: n/a
this might be stupid but did you let the clutch beak in at all??? a lot of people do not know that...
Old Nov 27, 2005 | 07:46 AM
ladysman's Avatar
Default Re: Just dandy... (sycamore)
return it for the XTSS. This is the one I had...
Old Nov 27, 2005 | 11:08 AM
mike93eh
Guest
Posts: n/a
Default Re: Just dandy... (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">return it for the XTSS. This is the one I had...</TD></TR></TABLE>
well it said its good to 270 ft. lbs. of torque. im not going to be anywhere near there, so if i get one ounce of slippage, im going to be one pissed ************!
Old Nov 27, 2005 | 12:58 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">well it said its good to 270 ft. lbs. of torque. im not going to be anywhere near there, so if i get one ounce of slippage, im going to be one pissed ************!</TD></TR></TABLE>
I have a greddy kit @ 7.5 psi on my D16Y8.
I made 183whp/163tq with an ACT HDSS clutch kit
Part # HC5-HDSS, good to 223 ft/lbs. of torque. Should be around $300 (what I paid).
Old Nov 27, 2005 | 01:13 PM
nonvtecD's Avatar
Default Re: Just dandy... (boostincoupe)
I just ordered an ebay stage 1 clutch for $95 the other day. They're supposed to hold 200hp but for $95 i'll turn down my boost to keep it from slipping
Old Nov 27, 2005 | 04:12 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">I have a greddy kit @ 7.5 psi on my D16Y8.
Part # HC5-HDSS, good to 223 ft/lbs. of torque. Should be around $300 (what I paid). </TD></TR></TABLE>
i should have no problems then with the hd00 then... i hope. i paid $330 shipped for it. thanks will!!
DelSol-B18
Sep 24, 2012 12:28 PM
cletus11
Dec 10, 2011 04:34 AM
stevieteg
Oct 9, 2008 05:48 PM
JFG Kevin
Jul 14, 2004 08:40 AM
vjace
Jun 6, 2004 05:24 PM
