compression test results
Old Nov 27, 2005 | 06:59 AM
whoneedzvtec's Avatar
Default compression test results
hey guys, im really not that smart when it comes to this stuff but i did a compression test last night and this what i came up with: 145 145 145 145. this is supposed to be a 8.5:1 cr motor. it is a b18a and b18a head gsr crank and rods and cp pistons. does this seem like decent numbers for the set-up? thanks fellas
Old Nov 27, 2005 | 07:12 AM
turbotime's Avatar
seems good to me, my freshly built b17a1 @ 8.5:1 produces 150 across the board, so you look good!
*edit*: now go boost the **** outta it
Old Nov 27, 2005 | 07:24 AM
sewell94's Avatar
sounds about right to me, alot more has to do with your compression that just your pistons. Cams, are the other big factor. So it could also be a guage that reads low
Old Nov 27, 2005 | 07:51 AM
Jared's Avatar
was the test done with the motor up to temp and with the throttle open?
Old Nov 27, 2005 | 08:38 AM
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">was the test done with the motor up to temp and with the throttle open?</TD></TR></TABLE>
throttle was wide open but motor was cold.
Old Nov 27, 2005 | 08:52 AM
wade's Avatar
Default Re: (whoneedzvtec)
go drive it for 10 min or about, and try again with the throttle wide open
integraRS-T
Jul 3, 2007 07:45 PM
berettagtz117
Mar 6, 2007 04:09 PM
97grnrs
Jul 22, 2006 07:52 PM
greasemonkeys
Jun 21, 2005 09:19 PM
geminis2k
Oct 6, 2003 03:47 PM
